by tight fisted » Mon Nov 16, 2009 2:34 pm
Good Afternoon All,
I've a Whirlpool ADG 644 1X. The green light is flashing in sets of 7. There is water in the drain well which I haven't noticed before. Oh, and it won't work! Any ideas please?
tight fisted
- Appliance Forum User
by Penguin45 » Tue Nov 17, 2009 12:32 am
Flow meter failure. Again.
Use "Search", put 'flow AND meter AND whirlpool' in and select Dishwasher forum - loads of results.
by tight fisted » Thu Nov 19, 2009 2:50 pm
Anyone know where I can learn to count? Flashing 4 not 7. So reading other threads took off pump and drained sump. Now, whilst I was wandering around down there I noticed that the rear part of the big clear container, is it the monoblock, looked full of gunge. Disconnected top pipe but made no difference. Where do I go from here?
tight fisted
by Penguin45 » Thu Nov 19, 2009 6:26 pm
Four flashes is no drain detected in the time allowed. If the machine doesn't drain you may have a blockage or pump failure. If it does drain, but flashes the water level indicator may be jammed in the full position due to fat deposits. The microswitch on the back of the unit may be failing.
Water level indicator is
HERE.
The gunge in the container is the resin in the water softener unit - do not mess with it under any circumstancces.
by tight fisted » Fri Nov 20, 2009 11:05 pm
Many thanks Penguin 45. The state of things at the moment are :- there is no water in the sump. When the start button is pressed there appears no response at all and the green light starts to flash within a couple of seconds.
tight fisted
- whirlpool adp4501/05 green light continually flashing
by stevesaddler » Fri Feb 04, 2011 10:41 pm
- 844 Views
- Last post by stevesaddler
Tue Feb 08, 2011 8:15 pm
- Green light flashing all the time
by JL33 » Tue Sep 07, 2010 8:19 am
- 763 Views
- Last post by JL33
Tue Sep 07, 2010 10:25 am
- adp 4400 4 flashing green light
by guesty1977 » Fri Oct 19, 2012 11:32 am
- 194 Views
- Last post by Muv
Fri Oct 19, 2012 12:13 pm
- hotpoint bf162 right green light flashing
by snagsman » Wed Oct 17, 2007 12:04 am
- 1151 Views
- Last post by iadom
Wed Oct 17, 2007 9:42 am
- Indesit IDL40 Dishwasher - 1st green light flashing
by susywoozy » Mon Aug 23, 2010 4:52 pm
- 7 Replies
- 2733 Views
Mon Aug 23, 2010 7:04 pm
Users browsing this forum: Alexa [Bot] and 38 guests
