8 year old Bosch Classixx (SGS43C12GB/08) Dishwasher Problem
Re: 8 year old Bosch Classixx (SGS43C12GB/08) Dishwasher Pro
Postby Watson306 » Mon Jan 23, 2012 4:10 pm
kwatt wrote:Usually as they spin they send an impulse to the board and a magnet is what the little board will sense spinning around.
If it doesn't sense the spinning of the rotor inside, it won't work.
How did you test it with a magnet? And, even at that, is it not possible that the magnet you used to test could be way stronger then the little one in the flow meter as it will be tiny I should imagine and not powerful at all?
I can see what your saying Kwatt. I may give it a go - trying to fit a new reed switch in it then. I have seen these on ebay, and it looks about the same spec:
http://www.ebay.co.uk/itm/Reed-Switch-180vAC-0-5A-2-Pack-SW925-/160475672964?pt=LH_DefaultDomain_3&hash=item255d187184
Worth giving it a go as I am a bit handy with a soldering iron.
Watson306
Postby kwatt » Mon Jan 23, 2012 4:16 pm
Why not just get the right part and be done with it? Seems a lot of hassle for what isn't a very expensive part.
Postby Watson306 » Mon Jan 23, 2012 7:51 pm
kwatt wrote:Why not just get the right part and be done with it? Seems a lot of hassle for what isn't a very expensive part.
Sorry, didnt see your reply - am desperate to get it working so went to maplins and brought a reed switch there - fitted it and no change.
Do you really think that a new part would be any different - I cant see that it would???
I realise the part is not that expensive, but I was desperate to get it fixed, and obviously if I can get it fixed cheaper than buying a new part then its a bonus. It really wasnt that difficult either, also I wasnt convinced after testing it either.
Is there really anything else it could be?
Watson306
Re: Re: 8 year old Bosch Classixx (SGS43C12GB/08) Dishwasher
Postby Martin » Mon Jan 23, 2012 9:09 pm
Watson306 wrote:Is there really anything else it could be?
No.
You asked for expert help and we gave it. Your choice... :(
Postby Watson306 » Mon Jan 23, 2012 9:22 pm
No.
Martin,
Why are you being like that?
I did ask for expert advise, but have I done anything that goes against the advise you have given me?
If you feel I have please say?
Watson306
Postby twicknix » Tue Jan 24, 2012 6:51 am
My experience on Bosch appliances, you cannot mess with it using parts not designed/built for this particular model. It is best to follow the advice. Bosch appliances are fickle when it comes to putting things right, do it well and it will reward you. Failing that, you will end up hating the appliance and start wishing you had taken the advice in the first place. Few more nights of washing up never hurt anyone!
"Problems are like washing machines, they twist us, spin us and knock around.
But in the end we come out cleaner, brighter and better than before!
Source - http://www.goodreads.com/quotes/show/535547"
twicknix
Postby nomadPaul » Tue Jan 24, 2012 8:18 pm
With the impellor jug , its rarely the reed switch that fails . Its normally the magnet falling off the impellor blade itself thats the problem ! If you hold the impellor jug and blow into one end , you should see the inner impellor spinning with the black magnet showing. If the blades are white then the magnet has vamooshed and a new impellor jug is the only answer
nomadPaul
Postby Watson306 » Tue Jan 24, 2012 8:55 pm
Thanks guys, I will take another look then.
Watson306
Postby Watson306 » Tue Jan 31, 2012 1:24 pm
Thanks everyone for there help on this.
Just for anyone else with a similar problem - I should have taken notice of Martin sooner, as a new flow meter did resolve this issue.
Thanks, and appologies if you took offense Martin. It wasnt intended.
Watson306
Postby kwatt » Tue Jan 31, 2012 1:30 pm
When did you order that, we haven't' sold one for ages?
Postby Martin » Tue Jan 31, 2012 5:09 pm
Watson306 wrote:Thanks, and appologies if you took offense Martin. It wasnt intended.
None taken and I'm pleased the problem was finally resolved. 8)
Postby Watson306 » Wed Feb 01, 2012 12:14 pm
It appears I spoke to soon, as although it completed that first wash it is doing the same again, and now sometimes with the door open, so I have removed the float off the bottom to test in case it was the float switch because there is no water in the bottom.
Any ideas, or is it looking like the PCB has gone?
Watson306
Postby Martin » Wed Feb 01, 2012 4:19 pm
Watson306 wrote:Any ideas, or is it looking like the PCB has gone?
Very likely but do check that the impellor jug connections are good at the PCB. Connections between the two can be an issue also. PCB about £90 'ish. :(
Previous
Users browsing this forum: No registered users and 41 guests
In total there are 41 users online :: 0 registered, 0 hidden and 41 guests (based on users active over the past 30 minutes)
