Australasian Appliance Forum
Fisher Paykel GW611 code 49
by rogerjet » Thu Mar 26, 2009 11:09 pm
Apologies as this could be a double post. I posted last night but I can't see the post so I am posting again.
I came home to a beeping washing machine (it had been off).
It has 0011001 code 49 inlet valve fault (advice from F&P).
The machine just beeps and displays code unless I unplug the machine. When plugged back in beeps and code. If I press start lights go out beeping stops and I have lid lock light flickering.
I have measured the resistance of the cold and hot water valves and they are 61 and 63 ohms respectively.
What I am wondering, is the problem the valve or controller.
Thanks in advance for any help.
rogerjet
 Freezer flap or drawer front broken?
You can buy replacement plastic freezer flaps and drawer fronts in our store here to fit all popular makes including for built in and integrated models from Diplomat, Lamona, Beko, Hotpoint, Bosch and many more
Do check carefully when ordering flaps as although many look the same they may well not be, if you are unsure please email to ask for assistance and we'll find it for you
plastic freezer flaps and drawer fronts for most fridge freezers and freezers including built in and integrated from popular makes like Hoover, Zanussi, Smeg, Diplomat, Hygena and many more
by Penguin45 » Fri Mar 27, 2009 9:13 pm
Cold water valve fault. Possible faulty wiring or connections; solenoid may be o/c - use test meter to check. Coil should read 64ohms.
by rogerjet » Fri Mar 27, 2009 11:08 pm
thanks
i have tested both valves by applying voltage directly to the coil. both opened and let water.
im guessing it must be the controller. i checked the wiring all looks ok.
any other ideas
thanks
rogerjet
by Penguin45 » Sat Mar 28, 2009 12:52 am
Motor controller is a possibilty - it uses a triac drive for the valves. If you are a suitably cunning artificer, you might like to apply power to the valve through the loom and see if it still works. Failing that, yes, the pcb.
by rogerjet » Mon Mar 30, 2009 5:19 am
Thanks for the help penguin.
I tried applying power through the loom and valve still works.
I have ordered a new controlller. :cry:
Does anything need to be done when installing a new conroller?
rogerjet
by rogerjet » Sat Apr 18, 2009 10:09 am
Having a problem with this damn machine again. New board in and about 10 washes no problem.
Today it overfilled ie water all over the laundry quickly had to put it into spin to stop it taking water and drain.
Any ideas what this fault could be? I have no fault code coming up and when I installed the new board I set the size to 6.5kg. I have checked the size now and still ok for 6.5kg.
Any further help appreciated.
rogerjet
by jophil29 » Thu May 28, 2009 1:43 pm
Try the pressure tube connection to the new PC board.
Fisher Paykel service and parts.
jophil29
 Before you post it… search it!
Please, before you post and ask something that has been asked before (often many times) please use the search facilities available.
Here you can search the forums only, including trade forums with permissions
Here you can search the entire site including all articles, public forums and online store
Use the search function before you post!
