As an Admiral owner who was helped out immensely last time you just knew I would be back.
After a nice period of faultless operation my 2006 Admiral GC2224GEKW Fridge Freezer has stopped cooling and freezing and has started to make an unusual throbbing whirring sound. It appears to be coming from the lower section of the freezer. The noise is hard to describe. It sounds like a rhythmic throbbing which when the door is opened sounds clearer and is like a fan or motor turning slower than normal. It isn't a mechanical noise but the sound that fan blades make when turning. Clear as mud so far?
I turned the temp down in the freezer and it responded accordingly and cold air is being blown in but I think that it is residual cold air from the cooling tubes.
Does anyone have any advice and a rough estimate of possible repair costs? Any help will be gratefully appreciated.
Paul
P.S. I have edited the title and this post because the FF is clearly not working.
