Another Samsung Cold Freezer Warm Fridge Problem
Re: Another Samsung Cold Freezer Warm Fridge Problem
Postby lesleydow » Tue May 29, 2007 11:39 pm
B73 5LD thanks
lesleydow
Postby r600a » Wed May 30, 2007 7:08 am
Hi Lesley
Give Ian at Penn Electrical a call on 01902 331600 he will be able to help
Bryan
r600a
WTA Team Member
WTA Team Member
Postby lesleydow » Wed May 30, 2007 4:43 pm
Thanks Bryan I will ring him now...let you know what happens.
lesleydow
Postby lesleydow » Thu May 31, 2007 4:21 pm
Bryan, Rang Ian and he will come out on Tuesday. He didn't mention a call out charge though, perhaps it's an all in payment. Anyway thanks for taking the time to help, Regards, Lesley
lesleydow
Postby lesleydow » Tue Jun 05, 2007 2:58 pm
Ian came out today to look at f/f. Said it needs new evaporater cover and fan and will get back to me with a price. Does the fan come separately from the evap cover or together, just trying to estimate cost of repair to see if its worth fixing.
lesleydow
Postby Dales-Electronic » Tue Jun 05, 2007 4:44 pm
The fan and the evaporator cover come as a complete one piece item.
Dales-Electronic
Postby paulsh » Thu Jun 07, 2007 9:43 am
I've had all of these problems mentioned, and after basically learning from scratch what all of the parts were and did, found that the thermal fuse had failed. Now I've changed that, it worked fine for 6 weeks now its gone again. What is going on? i'm seriously considering moding the thermal fuse assembly and fitting a self resetting fuse in its place as this is a pain in the ar*e
paul h
paulsh
Postby r600a » Thu Jun 07, 2007 12:04 pm
Hi Paul
Did you refit the new thermal fuse in the correct position ?If this has failed in 6 weeks then its likely that you did not correctly fit it.
Bryan
r600a
WTA Team Member
WTA Team Member
Postby paulsh » Thu Jun 07, 2007 12:37 pm
Well when I removed the old one, it was wrapped in a foam sleeve which was cable tied to the de-icing heater. I managed to compress the sleeve enough to remove it without cutting the tie. The replacement went back in the same place which is why I'm a little lost as to why it has failled. if I replace it with a self resetting thermal fuse ,(RS do one that works at 45 degc, does anyone know what temperature it should be?) , surely that will work OK.
confused!!! :?
paulsh
Postby paulsh » Fri Jun 22, 2007 1:31 pm
My moded thermal fuse has been in for just over 2 weeks now, everything working fine so far. If anyone wants to try the same, I got the fuse from RS, part No.176-9081. it costs about £2.50 ,rated at 9amp and it resets on fall in temperature. In essence it works just like a thermostat so if it sees a temperature in excess of 45 degc, it will switch off and then back on again once it has dropped to 35 or so. Just remove the old unit from the fridge, cut off the foam and the see through plastic capsule. Open up the two crimps olding the old unit in place. Crimp on the new unit and cover/reseal with heat shrink tube- reseal the ends with silicone. Job done, why on earth Samsung didn't do that in the first place -other than to make money out of spares !!
paulsh
Postby r600a » Fri Jun 22, 2007 2:11 pm
The reason that its not done by manufacturers not just samsung is that WATER & ELECTRIC DOES NOT MIX. Unless the components are made and sealed correctly which I am sorry to tell you this does not and is not safe.
If the appliance develops a electrical fault and catches fire then you can be held on manslaughter charges and your house insurance will be void.
This is blunt but the safety devices are there for a reason and if placed incorrectly which i beleive you placed the new one incorrectly it would lead to premeture failure which is not a component failure.
Bryan
r600a
WTA Team Member
WTA Team Member
Postby helo_75 » Fri Jun 22, 2007 3:42 pm
agreed, 100%
basically what uve done paul is the equivalent of bypassing the thermal fuse
u never took the time to wonder WHY the THERMAL fuse had gone? and what its purpose was/is?
honestly, manufacturers spend millions per year in the development of these components. you should email them and save them a fortune
just another self modification post, and it should be noted that any engineer, on this site or anywhere do not recommend this, its both reckless and silly, the fuse is there for a reason .. please , think of this.. yes, your 'modification' works like a stat, the original fuse cuts out when a fault occurs, what if your fuse sticks in the on position, and a fault occurs?
yup the problem becomes inflamed, and COULD become a safety hazzard
incidentally, we got a memo from samsung, quoting that any modification, by ANYBODY, and that included the use of non samsung spares, would invalidate ANY guarantee, manufacturers or extended, and would definitely exhonerate samsung from ANY liability in any way shape form or manner
my question to you (and others, who thought it clever to attatch pc fans with duct tape and leave trailing wires) is.. is it really worth it for a few quid more?
i know the answer.. do you?
helo_75
Postby kwatt » Fri Jun 22, 2007 4:01 pm
Guys,
Perhaps we should publish some pictures of fridge fires on frost free to show people the danger that they place themselves and their families in by doing this sort of thing. Maybe that would get the message across.
Thermal safety devices are there for a reason, manufacturers don't fit them just because they feel like it or think it might be a good idea.
On frost free the placement and values are absolutely VITAL to ensure that it all works. This includes the overall internal temperature of the unit in operation, too hot or too cold and it can spoil food or make it not fit for consumption. And, let's face it, the reason that you bought a fridge was to keep food in, safely, that you're going to eat.
That's why we don't bodge them like this and why we're so negative on these types of fix.
Everything working fine... yeah till the first time it goes into an extended defrost and up in flames or someone gets sick from bad food.
Postby helo_75 » Fri Jun 22, 2007 9:53 pm
exactly
helo_75
Postby paulsh » Mon Jun 25, 2007 7:26 am
utter garbage, it still has a thermal fuse!!!!!!!!!! and if you read it properly it is sealled.
paulsh
PreviousNext
Users browsing this forum: apronedsamurai, Google [Bot], Google Adsense [Bot] and 37 guests
In total there are 40 users online :: 3 registered, 0 hidden and 37 guests (based on users active over the past 30 minutes)
