Another Samsung Cold Freezer Warm Fridge Problem
Postby ozpeter » Mon May 07, 2007 10:22 am
I have a Samsung RS21FCNS. The water filter indicator came on after use months of minimal use so replaced. Replacement didn't work either so I powered off the fridge and then on again.
The freezer has settled back to a nice -18 but the fridge stays at 11 or 12 even after 2 more reboots. 16 hours have elapsed.
There are no noises coming (and the water filter isn't working either)
Thanks - in advance - for any advice.
ozpeter
Re: Another Samsung Cold Freezer Warm Fridge Problem
Postby r600a » Mon May 07, 2007 12:19 pm
Hi Ozpeter
You will need to replace the evaperator cover,available from both the shop on line or myself.
bryan
r600a
WTA Team Member
WTA Team Member
Postby THE BLACKSMITH » Thu May 10, 2007 7:02 pm
:( Hi folks, new to this blogging. Had my Samsung RS21 DCNS just over a year. Looks like a common problem, the water dispenser doesn't work any longer (have already ordered a new filter) and now find that the fridge seems to be cold at the bottom and warm at the top! From other reviews it looks like the drain hole is too small and frosts up, but where is the drainhole???????? Is this something I can deal with myself? Any help would be much appreciated........especially as the white wine isn't cold enough! Freezer works by the way. :rolls:
THE BLACKSMITH
Postby r600a » Thu May 10, 2007 7:31 pm
Hi Blacksmith
as above ..
You'll need a new evap cover available either from myself or the on line shop.
Bryan
r600a
WTA Team Member
WTA Team Member
Postby machineman » Thu May 10, 2007 7:56 pm
what about the sensor.m
machineman
Postby r600a » Thu May 10, 2007 8:29 pm
Hi Machineman
The sensor would only normally stop the unit from defrosting,when you have the water tank frozen which is the probable cause of no water being dispensed it points to the insulation failure of the evaperator cover.
Blacksmith,you will find that behind the water tank at the bottom you will have ice forming on the white plastic.
Also blacksmith if your fridge freezer is less than 2 years old then it will still be under samsungs warranty,you will need to provide your receipt and full model number and serial number for the warranty.Call 0870 7267864 (0870 samsung).
Bryan
r600a
WTA Team Member
WTA Team Member
Postby machineman » Fri May 11, 2007 6:55 am
or not defrosting.m
machineman
Postby THE BLACKSMITH » Sun May 13, 2007 1:09 pm
Hi Guys, thanks for the help re: changing the evaporator cover. Only trouble is I can't seem to get past the 4 screws...............HELP!!!!! How on earth can I remove this cover I'm getting really frustrated. I had a look at it the other day and after fiddling with it, the problem had a temporary cure. We had water from the dispenser again and the fridge seemed to get colder..............only trouble is it only lasted a couple of days hence trying again to remove the evap cover only to find it won't budge, please, please can someone help. :?:
THE BLACKSMITH
Postby machineman » Sun May 13, 2007 4:28 pm
its frozen, leave it off for 24hrs to thaw ,leave door open and it should pull off.m
machineman
Postby cyoules » Tue May 15, 2007 8:36 pm
what a great site! Just taken my evap cover off having experienced noise (& ignoring it!!), then temp flashing at 5, then after re-boot going to 17 odd.
Can you not buy the fan as a seperate part?
Is it likely to be the fan that is the only faulty bit?
What about the thermal fuse? Where is it?
Many thanks
cyoules
Postby r600a » Wed May 16, 2007 3:24 am
Cyoules
the fan wont normally be faulty,The evaperator cover will nrmally be needed to be changed,switching off and reseting or defrosting is a short term measure as a get you by.
Sqwitching off and defrosting will NOT cure the fault it will only give you a few days or a couple of weeks freedom.
The thermal fuse would only need to be changed if the defrost system was faulty beacuse of the thermal fuse.
Bryan
r600a
WTA Team Member
WTA Team Member
Postby lesleydow » Sat May 26, 2007 9:56 am
I am also having problems...no water being dispensed, water tank freezing up. warm fridge. An engineer came out two days ago and checked it saying there was nothing wrong except drainage hole needed unblocking. 'Great 'I thought, the next day though it all freezed up again. Don't know what to do now.
lesleydow
Postby Simon46 » Sat May 26, 2007 10:02 am
Try a UKW engineer (Repairs@).
Simon
Simon46
Postby lesleydow » Tue May 29, 2007 4:36 pm
Tried repairs@ all three options couldn't help.Help!!!!!
lesleydow
Postby Simon46 » Tue May 29, 2007 4:56 pm
What is your postcode?
S.
Simon46
Next
Users browsing this forum: No registered users and 27 guests
In total there are 27 users online :: 0 registered, 0 hidden and 27 guests (based on users active over the past 30 minutes)
