by jccandy » Fri Aug 24, 2007 6:43 pm
My Fridge is continually frozen up even though control is set to 0.
No light showing on the control knob
Liquid in bottles frozen
Recently moved from one room to another
Candy will fix for £100.
Can anyone confirm what the problem is and if there's an easy solution.
the freezer appears to be ok
thanks
Jonathan
jccandy
by Penguin45 » Fri Aug 24, 2007 11:23 pm
As with all combi fridge freezers, you start with a total defrost, then go again and see what happens.
by kwatt » Fri Aug 24, 2007 11:39 pm
Sounds like a PCB failure which is probably enough reason to pay the ransom money.
by jccandy » Sat Aug 25, 2007 11:10 am
Thanks for the advice, defrosting fingers crossed
J
jccandy
by jccandy » Sat Aug 25, 2007 12:28 pm
Have defrosted no joy though.
It's immediately cooling again even though the dials on 0.
Also no light on the dial control regardless of the setting.
Do you think this indicates the PCB fault referred to?
Thanks again
jccandy
- Candy Fridge Freezer CPCA 291FFK
by niall50 » Sat Dec 02, 2006 10:48 pm
- 7 Replies
- 1814 Views
Sun Dec 10, 2006 6:40 pm
- Candy CPCA 291 FFK Fridge not cooling
by CaptainK » Wed Aug 09, 2006 7:32 am
- 5 Replies
- 1452 Views
- Last post by BobHope
Thu Aug 10, 2006 5:43 pm
- Electrolux Fridge Freezer - frozen fridge!
by sezicoolcat » Fri Sep 21, 2007 8:09 pm
- 5 Replies
- 1732 Views
- Last post by whitevanman
Sun Sep 23, 2007 10:21 pm
- candy cpca 300k
by Nameless121 » Sun Nov 06, 2011 5:24 pm
- 4 Replies
- 547 Views
- Last post by Nameless121
Sun Nov 06, 2011 8:23 pm
- frozen drain hole in Hoover A Class fridge freezer(HCA310K)
by mandroid » Sat Jul 14, 2007 11:07 pm
- 5 Replies
- 1420 Views
- Last post by Simon46
Sun Jul 15, 2007 3:11 pm
Users browsing this forum: captaincaveman1 and 18 guests
