We have a Daewoo FRS 2021 WAl, had it around 9 years from new and up to now without problems.
A couple of months ago for no reason the whole unit stopped, Lights, Sensor on the front, Fridge and the freezer, the whole thing, like no power to it, I checked the fuze, okay, then the socket, that was okay,
Then a number of hours later switched it back on from the socket, and bingo, it worked. GREAT, This has happened a couple of times over the last few months until last night
the same thing happened, tried the same as last time, get a quick flash of light on the control panel then nothing.
Is this a problem with the PCB or could it be something cheaper like the run capacitor ? Thank you in advance for any advise you may be able to give.
Paul
