by TommyGun1 » Sun Apr 01, 2012 3:45 pm
My Daewoo FRSU20DCB is not making ice both fridge freezer are cold but not cool enough the top part of the freezer seems to be warm
1. The pipe that supplies water to ice maker is warm.
2. The freezer fan runs but not all the time
Temperatures in use: Fridge 6 (full) Freezer -21
TommyGun1
by folthik » Mon Apr 02, 2012 7:58 am
this type of f/f has 12 volt dc fan motor that is prone to going intermittently faulty.the fan might run a short time after say opening and closing the door or post defrost cycle,while for the vast majority of time remaining inoperative. This would cause the top of the freezer section to feel warm stopping the production of ice in the cabinets ice maker.Replacing the evaporator fan will cure this, though stripping the the frzr sctn down is a little tricky,and req's some patience.
folthik
by TommyGun1 » Tue Apr 03, 2012 2:42 pm
Thanks for the reply folthik
I am also having frost build up on the back of the freezer, a few days ago I cleared ice build up from the freezer evaporator coils using a hair dryer which helped but the frost is now showing on the back panel.
TommyGun1
by bazza500 » Tue Apr 03, 2012 2:57 pm
This can also be a symptom of a faulty fan. If the fan is not running the cold air is not circulating, therefore the freezer thinks it's not cold enough and keeps the compressor running causing frost build up.
bazza500
- WTA Team Member
by TommyGun1 » Wed Apr 04, 2012 1:23 pm
bazza500 wrote:This can also be a symptom of a faulty fan. If the fan is not running the cold air is not circulating, therefore the freezer thinks it's not cold enough and keeps the compressor running causing frost build up.
Thanks for your reply
The freezer has reached its set temperture and is also started making ice, looks like it's the fan which sometimes makes rattling grinding sounds.
TommyGun1
- Daewoo Fridge/freezer FR-520NT making noise coming from fan
by fmontana » Mon Jul 18, 2005 11:09 am
- 5 Replies
- 2001 Views
- Last post by Dave_Conway
Mon Jul 18, 2005 4:13 pm
- New Whirlpool not making ice cubes
by polycage » Tue Dec 21, 2004 11:46 am
- 9 Replies
- 3052 Views
- Last post by Guest
Thu Jan 01, 1970 12:00 am
- Freezer with Ice Making Facilities
by GUEST » Thu Apr 14, 2005 9:56 am
- 1131 Views
- Last post by kwatt
Thu Apr 14, 2005 9:58 am
- Samsung RS21DCSV not making ice
by bustermove » Wed Jan 10, 2007 8:29 pm
- 781 Views
- Last post by bustermove
Thu Jan 11, 2007 7:10 pm
- whirlpool s20eraa2v.not making ice
by doormaster » Wed Feb 25, 2009 1:33 pm
- 856 Views
- Last post by doormaster
Users browsing this forum: Google Adsense [Bot] and 31 guests
