I have read the below pasted posts with interest and would be appreciative for more of your help and guidance!!
I believe I have a very similar problem to slytrellis "Samsung Side by side fridge freezer problem slytrellis" Posted: Fri Jan 13, 2006 7:29 pm
I have a Samsung Side by Side Fridge-Freezer Model No. RS21FGRS. It was bought unfortunately 7/10/2003 - so is 2.5 years old. This model has ice and chilled water dispensers activated by levers and a bottle hatch - small door in fridge door.
My fault symptoms are the fridge has started to emit strange noises from inside the fridge, sounds like a fan or something like that and does come to a gradual stop when either door (main or milk/bottle hatch) are opened. I have read some posts that indicated that it may need a full defrost - is this just the fridge you defrost? I did look behind the two trays last night and found a small amount of ice forming between top tray and back panel, I've removed that and now the Temperature is showing 11c and when I change it to 3 or 2c changes back to 11c ( Temp. inside fridge though does seem OK)? I have switched the unit off and then back on and the digital display instantly showed a Temp. of 3c then changed to 11c? - Is there a reset setting at all?
Do you think the forum could guide me through fault diagnostics?
So any suggestions, I'm keen to try and fix it myself as I'm currently unemployed and we don't really have any cash right now especially for a New Fridge freezer!!!! Thanks again - Simon - hcr.hip@googlemail.com
Previous posts :-
chip Posted: Wed Jan 25, 2006 8:14 pm
If the noise you had was a grinding noise from the fridge and when the fridge door was opened the noise stopped it will be the Phlenim(rear poly block behind water tank)common fault.Samsung have now upgradded the material.I always change the Phlenim and evaportor sensor.Worth doing and should not cost that much unless there is a heater/sensor or thermal fuse fault.You get a 2 year warrenty with samsung
Weirdjam Posted: Wed Feb 01, 2006 12:21 pm
yes it is the part the fan is mounted to. If you pull out the bottom 2 drawers you will see the cover (and if close enough 2 screw holes where the water tan k affixs-yours doesnt have the tank as you say but its the same plenheim.)
slytrellis Posted
The noise did stop when the fridge door was opened. When you say "water tank" what do you mean. This model doesn't have water/ice dispenser.
Is the "Phlenim" the rear panel on the insidr of the fridge with the fan mounted on the back of it?
Also, do you supply spares for these as I have been unbable to findanyone who can. If you can how much would a Phlenim and evap sensor cost?
Unfortunately the unit is about 2 1/2 years old and out of warranty.
slytrellis Posted: Sun Mar 19, 2006 9:54 am
Well everyone, just thought I needed to update everyone. Having sent several letters to Samsung regarding the excessive cost of repairs on a fridge that was only 3 months out of warranty, they finally gave in and agreed a free of charge repair..... only after i threatened to go to BBC watchdog program about the problem... so after 4 Expert App visits, 3 sensors, 2 phlenims and a defrost heater and about 5 hours of labour everything is working!!
