Hello,I have this problem where the cabinet runs ok when first switched on but once it has cycled on the controller doesn't come back on.
Powering the unit off & then On Resets the PCB
& it works
I read that it could be a defrost problem.
I checked temp sensors reading 5.8K impedance i reckon it's ok
I checked thermal fuse for continuity OK
I checked defrost heater(stuck to the plastic tray) reading 8.4k impedance ,is this ok????
Is the defrost heater the problem???
could be the pcb???
thanks for your help in advance
