Hello, I found this site when I was trying to figure out what to do about my RL36 Samsung Fridge/Freezer. The fridge part does not seem to be working, though the freezer section is (and seems to be too cold)
We noticed that there was a lot of ice build up in the bottom freezer compartment floor and the ice maker was starting to get frost covering it (this does not normally happen). I took all the shelves out, removed the ice from the bottom and undid the rear cover of the compartment. There was a lot of ice behind it. I removed this ice as well.
After this was done, I noticed that the fridge part was now not working. IE, it's not getting cold. When I took the rear cover of the freezer compartment I did notice that the fan and flap were working OK (the flap rotated all the time. Should it do this?).
The freezer temp is -17 and the fridge is 1. The lights are working, and I notice the fridge light does go off when the door is shut. I can't feel any cold air getting coming out of the vents.
Can anyone advise if there's anything I ca do before going to the expense of an engineer?
