by pin » Wed Apr 06, 2005 9:42 pm
Hi,,i have a Zanussi Zss 7/5x fridge-freezer but have been having some problems for the lasst 48 hours. The machine started to leak water from the freezer side,,after having alook i saw it had begun to defrost. The fridge temperature also dropped but is now almost back to normal.
I was under the impression that this model auto-defrosted continually with no need for a turn-off/complete defrost. saying this the freezer temperature has still not risen even though no ice reamains ( there was very little to begin with).
Any advice would be great as the service centre did not even bother returning my call.
Thanks in advance.
pin
- Appliance Forum User
by Dave_Conway » Thu Apr 07, 2005 8:46 am
Can you hear the motor running ?
It may be just the thermostat in the fridge which controls the whole appliance.
by pin » Thu Apr 07, 2005 10:10 am
yes,,i can hear it running and theres the sound of running water in the freeezer,but the thermostat is turned up to the highest.
Also the fridge temperature seems to have dropped again. Something very odd here ,it cant be defrosting for 72 hours.
pin
by Dave_Conway » Thu Apr 07, 2005 10:24 am
It's not defrosting, there is a problem with the system (Compressor/Gas) by the sound of it.
Time for an engineer to be honest, check repairs@ and the directories, there should be one there who can help, if not, pop up your postcode here.
by pin » Thu Apr 07, 2005 10:31 am
Not what I wanted to hear but thanks anyhow :/
pin
by pin » Thu Apr 07, 2005 10:35 am
Hi,,i put in a repair request through your form ,nice idea btw, but could you give me a ball park figure just so I know what to expect. Thanks.
pin
by Dave_Conway » Thu Apr 07, 2005 10:49 am
pin wrote:nice idea btw
pin wrote:but could you give me a ball park figure just so I know what to expect. Thanks.
That's not an easy one as labour rates vary from region to region, you can discuss that with the guys that the call went to. As far as the repair goes, hopefully it may require a gas top up, worst case scenario is a major internal leak which would render the appliance beyond repair. Compressor replacement would normally be somewhere between £125-£175 in total (ish).
by pin » Thu Apr 07, 2005 10:52 am
okey doke,,lets hope its the gas then,,thanks for the help ,,i'll post back with the results later.cheers
pin
by pin » Sat Apr 09, 2005 10:30 am
lo again ,,, worked out what it was,, one guy said if the door had been left open for a period of time it could cause a build-up of ice inside that the auto-defrost couldnt handle. He recommended i turn it off for 24 hours and then try. Just did and all is well. w00t
pin
- Zanussi ZFK.61/27
by rigger » Wed Mar 02, 2005 7:49 pm
- 4 Replies
- 1887 Views
- Last post by rigger
Fri Mar 04, 2005 7:46 am
- zanussi
by waters » Tue May 10, 2005 6:49 pm
- 1225 Views
- Last post by eastlmark
Tue May 10, 2005 8:04 pm
- Zanussi ZFK 61/27 r - Help !!!!
by Pete C » Thu Dec 29, 2005 12:38 pm
- 5 Replies
- 2025 Views
- Last post by Pete C
Thu Jan 05, 2006 9:25 am
- zanussi z1 920/8 ff
by jim kelly » Sat Mar 10, 2012 6:44 pm
- 308 Views
- Last post by captaincaveman1
Sun Mar 11, 2012 6:35 pm
- Zanussi ZNB 323
by maxascent » Wed Apr 25, 2012 1:57 pm
- 299 Views
- Last post by Seamy
Thu Apr 26, 2012 5:53 pm
Users browsing this forum: No registered users and 28 guests
