Hotpoint 8112 Larder Fridge - how to replace thermostat?
by The Spikey Fridge » Tue May 10, 2011 11:14 am
The thermostat's gone in my fridge. I was gonna replace it with a Ranco Varifix VX-0.
However I can't work out how to dismantle the existing thermostat.
How is it even fixed in, there appears to be no screws?
Also - what's the silver (uncoated) wire at the top and how does it fix into the thermostat? (all the coated ones look like they just 'plug in')
(see pics below)
Thanks. :)
The Spikey Fridge
 Get fridge water filters
You can buy replacement fridge water filters including many low cost compatible water filters in our store here for all major fridge freezer makes including American fridge freezers as well as built in and integrated models from Samsung, Hotpoint, LG, Liebherr, Maytag, Whirlpool and many more
by don » Tue May 10, 2011 12:03 pm
Resized your pictures so they fit the board. Much easier to view as well :wink:
EDIT: You can attach photo's to your post via the "attach button", saves having to use a hosting site :D
Don
Please keep your questions to the forums, emails and private messages will not be answered.
don
by The Spikey Fridge » Tue May 10, 2011 1:54 pm
Thanks - didn't see the attach photo button. :oops:
The Spikey Fridge
by The Spikey Fridge » Tue May 10, 2011 6:35 pm
OK, I've read up a bit more and understand the 'silver wire' is a capillery tube full of gas.
I can't see where it goes to once it reaches the back of the fridge (thermostat's at the front). Do I need to replace that tube? If not how does it connect to the 'stat?
ta.
The Spikey Fridge
by kwatt » Tue May 10, 2011 7:04 pm
It's worth prodding about the articles, you'll find some like this one that will explain a lot. ;)
That should offer some enlightenment.
by The Spikey Fridge » Tue May 10, 2011 7:26 pm
Cool, thanks. Have read around, but still stuck on where the capillery tube goes to in my fridge.
I've managed to dismantle the thermostat (pulled the knob off :o and undid the nut behind) but the tube looks soldered on. I can pull all the other wires off, but I assume I've got to replace the tube & the thermostat together?
Tracing the tube to the back of the fridge it goes behind the metal plate at the back. I've undone the three fixing screws but there's something still holding the plate in place - how do I get behind it?
The Spikey Fridge
by kwatt » Tue May 10, 2011 7:44 pm
Usually it'll pop off somehow but, don't be too rough as if you rupture a pipe it's game over and night, night Sooty for the fridge.
Why didn't you just use a the proper thermostat, this one, rather than faffing about with a Ranco kit. You'll probably have to wind up the capillary in the stat housing, which can be fun.
Just seems a lot of bother to go to.
by The Spikey Fridge » Tue May 10, 2011 9:29 pm
Maybe I will get that 'proper' one - the Ranco one was the first one I found.
When you say the back plate should 'pop off', how should I try working it? Sliding? Up/Down? Or rotating? Or just pullingit towards me? I've never taken one off before so no idea.
Is it a pipe that's currently stopping it from coming away?
The Spikey Fridge
by kwatt » Tue May 10, 2011 9:34 pm
Not done one.
But, usually it will lift up enough somehow or move in some way to allow access.
by iadom » Tue May 10, 2011 9:49 pm
At the bottom of the plate there are two screws at either corner and two other screws close together.
Release the two at each corner to allow the bottom edge of the plate to be 'gently' moved forwards, you don't need to remove the top one, then release the other two screws which hold the plate that clamps the end of the capillary tube in place.
Please submit your questions in the relevant forum. Unsolicited PM's and emails will not be answered.
 Fridge & freezer door hinges
You can buy replacement door hinges in our store here to fit all popular makes including Ingol, Hettich and other hinges for built in and integrated models from Diplomat, Lamona, Beko, Hotpoint, Bosch and many more including many cheap compatible hinges
Door hinges for most fridges and freezers including built in and integrated from popular makes like Hoover, Zanussi, Smeg, Diplomat, Hygena and many more
