Indesit KD3C1(W)/G Thermal Fuse?
by Miss Lemons » Thu Oct 12, 2017 1:59 pm
Afternoon,
My oven (Indesit KD3C1(W)/G) trips the electrics whenever I switch it on at the wall. It has previously been working fine – it tripped out halfway through cooking dinner using two hobs. Now it trips the electrics without any hobs or grills or the oven itself turned on, just being switched on at the wall socket.
I have checked unscrewed the wall socket and there is no obviously damaged wiring.
I have unscrewed and removed the back of the oven and there is no obviously damaged wiring.
Next step, I understand, is changing the fuse? Should there be a thermal fuse inside the oven I can find now the back is off? I'm having difficulty locating it. Or is there another next step of dissassembling it further and seeing if the thermostat etc. are scorched?
Thanks for your help!
Miss Lemons
by kwatt » Thu Oct 12, 2017 2:09 pm
No there's not any internal fuses.
Mains terminal block, light fitting, switch, any element could cause that. Elements far more likely when in use to be fair.
by Miss Lemons » Thu Oct 12, 2017 2:58 pm
Thanks for the info kwatt! That puts a final end on Fusequest.
Miss Lemons
 Get new oven shelves and trays
If you need an extra shelf, a new shelf or a new grill pan for your built in oven or cooker you can find replacement shelves and grill pans in our store for all major brands including Belling, Bosch, Smeg, Beko, Lamona, Diplomat and many more with many low cost compatible shelves and pans available
Buy oven shelves and trays for built in ovens and cookers online
 Oven & cooker switches
We supply switches and most other oven and cooker spare parts to the trade and public in our online spare parts store at terrific prices for all major brands including Smeg, Beko, Leisure, Stoves, Rangemaster, Britannia and many, many more
Shop online for
                        cooker and oven spare parts
