Logik L612WM13
by Anthony Morrison » Thu Oct 12, 2017 4:59 pm
Hello. My login washing machine is showing error code E21, overtime 3 minutes of the drainage. The machine is draining and pump spins freely yet still shows the error code?
Anthony Morrison
Does your washing machine stink?
If your washing machine stinks, smells bad or emits strange odours it is most likely to be caused by bacteria build up in the washer. To clean this we recommend using Affresh that you can buy here to clean out the bacteria. And for more detailed advice on washing machine odour you can read our article all about smelly washing machines here
Buy Affresh washing machine cleaner here to stop bad smells from your washing machine
by Anthony Morrison » Thu Oct 12, 2017 5:00 pm
Sorry. It is a logik machine
Anthony Morrison
by 1totalshambles » Sun Oct 15, 2017 8:26 am
E21 = pump out problem. If still shows this fault but does actually pump out water it is possible that pressure switch is at fault, it is quite common that they can fail either to cause over filling or the opposite = no filling at all or stuck on pump out because it thinks it has overfilled or blockage in air trap-follow the black hose from the pressure switch down to the air trap. There`s a rough / bad translation from Chinese on Partmaster just find your model and then find service manual. Tap side of pressure switch a few times with a screw driver handle, if that does cure it still change the pressure switch.
1totalshambles
Valued Contributor
Valued Contributor
