Noisy Siemens Fridge Freezer
by Stompa » Sun Oct 31, 2004 10:57 pm
I've got a Siemens KS24V02 Fridge Freezer, which has become pretty noisy.
It started emitting a very loud buzzing noise, I shifted it a bit and that seemed to reduce the noise. Subsequently I defrosted the freezer, and on switching it back on, the internal bulb blew, and the fridge did not restart.
A combination of switching it off and on a few times, and shifting the fridge a little seemed to coax it back to life, but it's now buzzing quite a lot when it comes on - any ideas?
It's around 8 years old, is it worth getting it repaired or would I be better off replacing it?
Stompa
Stompa
 Freezer storage drawer broken?
You can buy replacement freezer drawers in our store to fit all popular makes including for built in and integrated models from Diplomat, Lamona, Beko, Hotpoint, Bosch and many more
Do check carefully when ordering freezer drawers as although many look the same they may well not be, if you are unsure please email to ask for assistance and we'll find it for you
freezer storage drawers for most fridge freezers and freezers including built in and integrated from popular makes like Hoover, Zanussi, Smeg, Diplomat, Hygena and many more
by Penguin45 » Mon Nov 01, 2004 12:10 am
Sounds a bit tired..... The noise is probably coming from the compressor - it should be sitting on four rubber shock mountings. These settle over time and can lead to a variety of interesting noises, most of which, whilst irritating, are harmless.
Hopefully the bulb blowing was just a result of dampness caused by the defrost process.
Seimens/Bosch is generally decent gear - probably worth getting someone in to check it out - have a look in the Directories section for a UKW engineer in your area, or pop your postcode up and someone will pick up on it.
by Guest » Mon Nov 01, 2004 10:02 am
OK, thanks. I'm in Cambridge (CB4) - which doesn't seem to be covered in the Directories section.
Stompa
by tonyclifton » Mon Nov 01, 2004 1:22 pm
Stompa
what part of cambridge are you as i cover that area one day aweek
if you want someone to take a look let me know
regards
Tony
tonyclifton
Banned User
