Schreiber APM 6314 integrated fridge problem
by SSW » Tue Mar 08, 2005 2:35 pm
Hi, thanks for reading. Can anyone identify this problem?:
Fridge never goes down to the required cold temperature, ice forms very quickly on the element at the back in one big area.
Is it a relatively cheap repair? Thanks in advance for your help.
SSW
 Freezer flap or drawer front broken?
You can buy replacement plastic freezer flaps and drawer fronts in our store here to fit all popular makes including for built in and integrated models from Diplomat, Lamona, Beko, Hotpoint, Bosch and many more
Do check carefully when ordering flaps as although many look the same they may well not be, if you are unsure please email to ask for assistance and we'll find it for you
plastic freezer flaps and drawer fronts for most fridge freezers and freezers including built in and integrated from popular makes like Hoover, Zanussi, Smeg, Diplomat, Hygena and many more
by Simon46 » Tue Mar 08, 2005 2:38 pm
Does the motor run continuously?
Simon46
by SSW » Tue Mar 08, 2005 3:11 pm
Yes, I think the motor DOES run continuously.
SSW
by SSW » Tue Mar 08, 2005 3:22 pm
The appliance is approximately eight years old.
SSW
by SSW » Tue Mar 08, 2005 4:26 pm
So...break it to me gently...is it bad news? Or needn't I worry?
Thanks for your help chaps. :)
SSW
by clivejameson » Tue Mar 08, 2005 5:38 pm
sounds like the compressor is worn out SSW, beyond economical repair. Although its not a spring chicken at 8 years old, its still not that old...you need to check that the correct ventilation has been arranged in the housing.
Most require a large vent slot in the kick panel of the kitchen unit (can be covered with a decor grill) which allows air to travel under the appliance, up the rear of it (collecting the warmth of the appliance) and out through the top of the housing...bit like a chimney effect. Time and time again i see frs and fzs with no ventilation provided and they wheeze on for a few years before the compressor gets tired, by which time the installers are long gone.
All this will apply to your new machine too of course.
Clive
Sharley Domestics Repair and Sales
Light travels faster than the speed of sound...which is why some people appear bright until they open their mouth.
clivejameson
by clivejameson » Tue Mar 08, 2005 5:40 pm
just an after thought.....is the ice hard or is it snowy?....if its snowy then you might just have an airleak from worn/broken hinges
Clive
clivejameson
by SSW » Tue Mar 08, 2005 5:51 pm
Hmmm. The fridge has a vent at the bottom but not at the top so there is no chimney effect. The ice is a hard block and not snowy.
Anyone got any idea how much a new compressor should cost for this fridge? Not too much ££££ I hope. :cry:
Thanks in advance for your advice.
SSW
by clivejameson » Tue Mar 08, 2005 6:15 pm
no need to worry about the top...if the kitchen units don't touch the ceiling then there is sufficient space behind the housing (built in to their design) and the warm air will just rise up behind and up towards the ceiling.
...as to replacing the compressor...well it is the main event in any cooling product, it requires major surgery to replace (gas tight connections need to be braized or crimped) and then a fresh charge of coolant gas installed. The cost of the compressor depends on its size but it will certainly not be a cheap repair!
Clive
clivejameson
by SSW » Tue Mar 08, 2005 9:34 pm
Yeah, the label says R134a, and I guess because there is a big build-up of ice in one area at the back of my knackered fridge it would point to some sort of blockage, like you say.
Thanks for the link to a newer model. I wonder how much the CW781 would be... any ideas?
What an excellent forum this is. Thanks for all the advice so far.
SSW
 Fridge storage shelves and trays
You can buy replacement shelves and storage trays in our store here to fit all popular makes including shelves for built in and integrated models from Diplomat, Lamona, Beko, Hotpoint, Bosch and many more
Do check carefully when ordering a new shelf as although many look the same they may well not be, if you are unsure please email to ask for assistance and we'll find it for you
“Shelves
