Moderators: r600a, johnmac11, eastlmark, Jackal, Dave_Conway, don, iadom, Penguin45, Dales-Electronic, dquinn
by mark1892 » Sat Jun 14, 2008 3:13 pm
A relative needs a new latch receiver for a Hoover New Wave tumble dryer D6986. been told the item is now obsolete but they have just paid 40 quid for a new door so would really like to get hold of one.
thanks in advance if anyone can help. i will get the serial and model no now and post them up.
mark1892 on Sat Jun 14, 2008 3:23 pm, edited 1 time in total.
mark1892
- Appliance Forum User
by mark1892 » Sat Jun 14, 2008 3:20 pm
model no.37601432
serial no.D698671100144
mark1892
by Phidom » Sat Jun 14, 2008 3:58 pm
Part Number is 09088436. Best thing to do is make an inquiry with the spares shop at this site as they have access to various suppliers.
In Faecorum Semper Solum Profundum Variat.
Phidom
- Appliance Forum Veteran
by mark1892 » Mon Jun 16, 2008 12:10 pm
tried that mate thanx but no luck. the door closes fine but the prongs on the back which the switch clamp onto have broken off. having just paid 40 quid for the door, i am tempted to just bypass the switch or tape the plunger on the switch so it will work. i know its probs not a recommended fix but anything is better than scrapping it just for this.
mark1892
by Phidom » Mon Jun 16, 2008 12:33 pm
The latch receiver is just a plastic plate that screws on the outside of the cabinet, are you sure that's the part you mean?
Phidom
by mark1892 » Mon Jun 16, 2008 11:29 pm
yes mate it screws on to the cabinet but then the switch that the door pushes on, screws to it on the inside. to make it work when you shut the door.
mark1892
by Phidom » Tue Jun 17, 2008 7:11 am
I've probably got a secondhand one but I can't find any photos of the part so would be unable to identify the correct one.
Phidom
by mark1892 » Tue Jun 17, 2008 9:19 am
phidom, thanks for your help mate. whereabouts in the north east are you? i have managed to screw the switch onto the back of the latch receiver and is working ok at the moment but if you had one it would be better if i fitted that. i will take a pic of it next time im over there and post on here to see if you have a match.
regards
mark
mark1892
by Phidom » Tue Jun 17, 2008 8:06 pm
OK, I'm near Buckie.
Phidom
by sheer1delight » Thu Jun 19, 2008 7:47 am
Is this the same item as fits softwave machine. Microswitch fits on two posts of assembly which in turn bolts to front part of latch that is located on front of machine?
I could forward secondhand assembly.
Even better. Why not visit your local council/ scrapyard and buy a whole machine for a few quid? There is a chance you will find one there!
sheer1delight
by sheer1delight » Thu Jun 19, 2008 8:02 am
Ooops sorry. I thought this was a washer dryer.you were describing- my fault. Do you know if tumble dryer interlock is similar to that of washer or washer/dryer.
regards
sheer1delight
by mark1892 » Thu Jun 26, 2008 12:04 am
sheer1delight wrote:Is this the same item as fits softwave machine. Microswitch fits on two posts of assembly which in turn bolts to front part of latch that is located on front of machine?
already tried the recycle place. none that type. your description sounds right and it is off a softwave dryer, have you a pic??
mark1892
Return to Spare Parts Help
- Hygena APM 8620 tumble dryer door latch not working
by superchick » Sun Jan 01, 2012 7:28 pm
- 460 Views
- Last post by superchick
- Hoover TV30 Tumble Dryer
by mds228 » Mon Jan 31, 2005 10:47 pm
- 1649 Views
- Last post by dago
Tue Apr 26, 2005 7:52 pm
- Bearing kit for hoover TV630 tumble dryer
by jh57486 » Fri Nov 05, 2004 9:20 am
- 1042 Views
- Last post by Dave_Conway
Fri Nov 05, 2004 9:33 am
- Hoover Tumble Dryer Obsolete Spares
by neil692 » Sat Mar 15, 2008 4:19 pm
- 5 Replies
- 2305 Views
- Last post by electron1100
Fri Jan 16, 2009 8:18 pm
- Hoover TV630 Tumble Dryer Heating Element
by Bushy » Mon Oct 31, 2005 5:56 pm
- 1088 Views
- Last post by Bushy
Tue Nov 01, 2005 12:06 pm
Users browsing this forum: No registered users and 8 guests
