Spare Parts Help
Hygena Turbo oven glass
If you are looking for a spares for your washing machine, dishwasher, fridge freezer of any other appliance or need help with a part post a request in this forum and we will help you or jump straight to the online spares store from this link
Moderators: r600a, johnmac11, eastlmark, Jackal, Dave_Conway, don, iadom, Penguin45, Dales-Electronic, dquinn
Postby Dan Rogers » Wed Jan 12, 2005 7:12 pm
We managed to shatter our oven door glass during a houseparty last year and have had no luck finding a replacement, mostly becasue we haven't got a model number. It was either on the glass (which is now in a thousand bits) or has rubbed off the front. The landlord claims not to have the manual (and we certainly don't), it's also not on the inside as far as we can tell.
It is labelled 'Turbo by Hygena' and is a standard-looking four hob, oven and grill combined, electric unit. The glass looks like it should have dimensions approx 59cm*46cm (W*H) and covers the whole front of the oven, with the handle attached through the glass.
Can anyone advise as to a replacement? If any further measurements or identifying marks are required, let me know!
Thanks,
Dan.
Dan Rogers
Find an reputable appliance engineer for washing machine repairs, dishwasher repairs, fridge repair, freezer repairs, cooker repairs, oven repairs, hob repairs, fridge freezer repairs, washer dryer repairs, tumble dryer repairs
Postby kwatt » Wed Jan 12, 2005 8:41 pm
Dan,
Without a model numer it's going to be nigh on impossible to replace, but if you can get some photos sent then we may be able to identify it for you. ;)
Re: Hygena Turbo oven glass
Postby Guest » Mon Jan 17, 2005 11:26 pm
Hi, sorry for the delay,
I've uploaded three photos of our admittedly very dirty cooker to my webspace:
http://www.dnr.pwp.blueyonder.co.uk/cooker/cooker1.JPG
http://www.dnr.pwp.blueyonder.co.uk/cooker/cooker2.JPG
http://www.dnr.pwp.blueyonder.co.uk/cooker/cooker3.JPG
Hope this helps in identifying it!
If you need anything else, don't hesitate to ask,
Thanks very much,
Dan.
Postby Penguin45 » Tue Jan 18, 2005 12:10 am
Dan,
Ignore the hob, it is a separate item. If you check around the door opening, you should find four screws. When removed, the oven can be slipped forward and the other rating label will be revealed - on most of them it's on the top of the oven box but on a few it's on the back. You're looking fora number starting "ADP----" or perhaps "APM----". I'm afraid that without it you have virtually no chance of resolving this.
Pengiun45.
Postby Guest » Tue Jan 18, 2005 7:42 pm
I took the oven out as you suggested and found a rather dusty label:
Hygena
Serial No: 02237356 [Model 2]
Model: AHY3220 [White Mod2]
2.05kW 220-240V ~50Hz
No ADP or APM but an AHY. Is it possible to get a replacement front glass panel (not the inside glass, the exterior sheet)?
Thanks very much, I would never have tried looking there!
Dan.
Postby kwatt » Tue Jan 18, 2005 8:38 pm
Hi Dan,
We can pick it up from that information no problem at all. Get back to you in the morning hopefully with more information. Or, even better, if you drop an email to spares@ukwhitegoods.co.uk Dave will answer it for sure in the morning.
Postby Guest » Tue Jan 18, 2005 11:31 pm
I've e-mailed a request for a price to that address.
Thanks for the prompt responses guys!
Cheers,
Dan.
Postby neilR » Tue Jun 28, 2005 9:11 am
I have managed to do pretty much the same thing to my hygena oven except I have managed to break both the inner and outer glass.
My oven looks the same as the one in the pictures, in colour and lack of oven door, expect it only has the dial on the left.
I have a manual (which covers a range of cookers) and i'm guessing from that i have a AHY3120 does that sound right ?
cheers,
neil
neilR
Postby Dave_Conway » Tue Jun 28, 2005 9:35 am
neilR wrote:I have a manual (which covers a range of cookers) and i'm guessing from that i have a AHY3120 does that sound right ?
That is a good model number but I would be best to make sure before you ordered anything, details for this model are:
Inner door glass £36.30
Outer door glass £55.39
Postage £7.95
All inc VAT. If that is your model and you need to order, an email to spares@ukwhitegoods.co.uk please :D
Postby neilR » Tue Jun 28, 2005 10:11 am
OK, i follow the advice above to find the model number tonight and email you direct.
Also would you be able to supply the black goop that seems to stick it to the frame ?
cheers neil
neilR
Postby Dave_Conway » Tue Jun 28, 2005 10:13 am
The metal parts glued to the outer glass will come already glued in place, no gloop required :D
Postby neilR » Tue Jun 28, 2005 11:03 am
Are you sure you guys are in the trade, aren't you supposed to suck your teeth and say 'i dunno mate, the problem is see; that you got replace the whole thing and once you've done that you might well replace the hob ...'
thanks for the help dave expect a email tommorow :wink:
neil
neilR
Return to Spare Parts Help
Users browsing this forum: No registered users and 9 guests
In total there are 9 users online :: 0 registered, 0 hidden and 9 guests (based on users active over the past 30 minutes)
