Spare Parts Help
Indesit W161 drum bearing
If you are looking for a spares for your washing machine, dishwasher, fridge freezer of any other appliance or need help with a part post a request in this forum and we will help you or jump straight to the online spares store from this link
Moderators: r600a, johnmac11, eastlmark, Jackal, Dave_Conway, don, iadom, Penguin45, Dales-Electronic, dquinn
Postby cookm » Thu Jul 15, 2004 9:06 am
Has anyone else had a drum bearing go on their W161 washer?
Mine is just over a year old (typical, just outside warranty!), bought in March '03 at Comet, and when spinning it now sounds like concorde taking off! I reckon the W161 was an experiment by Merloni which went wrong (1600rpm is probably too fast a speed for the bearing!).
I've looked around and for this model two possible bearings are identified:- 6205-2Z or 6206-2Z
Can anyone help me to find which one is correct?
Many thanks,
cookm
Find an reputable appliance engineer for washing machine repairs, dishwasher repairs, fridge repair, freezer repairs, cooker repairs, oven repairs, hob repairs, fridge freezer repairs, washer dryer repairs, tumble dryer repairs
Re: Indesit W161 drum bearing
Postby Dave_Conway » Thu Jul 15, 2004 10:43 am
It will have both of those bearings, 6205 and 6206 as well as the shaft seal which will aslo need replacing.
I can sort the lot out for about £20 inc post etc.
If you want these ordered and sent to you, drop me an email.
Postby cookm » Thu Jul 15, 2004 12:18 pm
Cheers, Dave. I've e-mailed you...
Is this a common fault with this washer do you know? And if so is it because the bearing is not designed to take the high spin speed?
Thanks,
cookm
Postby Dave_Conway » Thu Jul 15, 2004 12:35 pm
Yeah I got the email, which I'll reply to directly, for others's benefit with similar problems..............
The bearing on this particular machine is no different than many others, several factors effect premature bearing failure:
1/ The bearing seal - stops water entering the bearing housing, the most common cause of bearing failure. Can be effected by, poor quality material used for the seals and drum support shafts, badly designed sealing arrangements.
2/ Poor quality bearings used in production (cost saving measures to keep appliance prices low).
3/ High spin speeds used constantly - 1600rpm is too high, you will see little difference if you reduced the speed to 1000rpm for most fabrics. High spin speed is a selling tool for retailers and manufacturers but is something us repairers will advise against in the main.
4/ Constant overloading, this coupled with all or some of the above will signifantly reduce the time it takes before bearing failure.
So, as a guide, buy a good quality appliance with a reasonable spin speed (1200rpm maximum), do your homework by asking an engineer and/or other people with machines that have lasted a reasonable timescale without too many major repairs, and the biggest one of all, don't be pulled in by the "low price" nonsense, all applinaces are not the same as is generally thought sometimes, you get what you pay for as they say ;)
Postby Longmeadow » Fri Aug 27, 2004 10:22 am
Another failed bearing..............How awkward is the repair job?
Longmeadow
Postby Dave_Conway » Fri Aug 27, 2004 12:13 pm
Longmeadow wrote:Another failed bearing..............How awkward is the repair job?
Fairly straightforward if you have general idea of how to go about drum bearing replacement.
Check around the public areas, there's lots of references to it.
Postby Guest » Wed Jan 05, 2005 10:13 pm
I read with great interest your problem. I bought an Indesit W161 washing machine from comet on 10th July 2003 so again just out of guarantee. My machine has also just died having become increasingly louder and chewed several items of laundry. I have contacted Indesit and was told I should have had extended guarantee.I have spoken to a local reputable repair company who have recommended getting rid of it and buying a decent machine. I will never buy indesit again. I have just bought a zanussi so hope it will be better.
Postby frost » Sat Jan 22, 2005 12:30 pm
just read your details on the w161 i have the same problem but now the clothes are getting covered in grease, i have written to indesit 2 weeks ago as mine is 17 months old still no reply customer sevice dont want to know, dont answer the phone we are now going to take the advice of one of your previous e-mails and throw it in the skip and go and buy another one one thats not an indesit
frost
Postby eastlmark » Sat Jan 22, 2005 12:50 pm
avoid Hotpoint, Creda and Ariston too as they are all the same company now.
eastlmark
Postby Guest » Tue Feb 15, 2005 12:26 pm
Hi all,just out of warrenty as usual machine kept filling with water and skipping cycles,( Indesit answer "oh that will be the Control Circuit board £78.00 delivered then pay someone to fit it,turned out to be a £1.00 piece of pipe from the pressure switch which had a slit in it where it had rubbed on the drum, this happened to be fixed by a very nice bloke who came to fix the fire, he used to fix washing machines, thanks mate
Postby tallapaula » Sat Aug 29, 2009 6:04 pm
Hi folks,
Its been a few years since I looked in on this fab forum and since id forgotten my old username I had to create a new account.
Not sure if I should resurrect this thread or not but anyways...
I also have an indesit w161. Had been quite happy with it for 5 or 6 years up to now but a few months ago notices spins were noisier and when I turned the drum by hand it seemed slightly rough.
Anyways I went to it today and lo and behold the drum is stuck fast and the clothes inside were still fairly wet.
So I took the back off and found the belt lying on the floor inside.
I guess its a no brainer that the bearings have gone and it has siezed but would appreciate any advice to the contrary if im wrong :-)
My main question is this...
I have seen reference on this thread to getting instructions on replacing the bearings in a "public area" Just really wanted to put the question out there as to which type of bearing Id need to buy to get the replacement done.
Thanks in advance :-)
Paula
tallapaula
Postby Penguin45 » Sat Aug 29, 2009 6:17 pm
HERE.
Postby tallapaula » Sat Aug 29, 2009 7:16 pm
Thanks penguin.
Do you know where I might find instructions somewhere on how to replace the bearings for this model?
I see from reading around that its quite an advanced job but what the heck. Im never going to learn if I dont try eh?
thanks again,
Paula
tallapaula
Postby Penguin45 » Sat Aug 29, 2009 7:37 pm
The quick "pot boiler" answer is:
1/ Remove the rear cover and lid of the machine.
2/ Remove the belt and drum pulley (Bolt is really tight).
3/ Remove crosspiece on the back of the drum - this contains the bearings and water seals. You will need a large hammer.
4/ Use a drift and hammer to drive out the bearings and seals.
5/ Clean everything, especially the shaft and the brass collar where the new seal will run.
6/ If the shaft is damaged in anyway, the machine is scrap as the cost of a new outer and inner drum assembly is prohibitive.
Stay safe, plug out, use safety glasses and gloves.
Good lick,
Postby tallapaula » Sat Aug 29, 2009 8:08 pm
Thats excellent thanks for the advice.
Do you think I should order up a new front door seal as well while Im at this?
thanks,
Paula
tallapaula
Next
Return to Spare Parts Help
In total there are 4 users online :: 0 registered, 0 hidden and 4 guests (based on users active over the past 30 minutes)
