Tumble Dryer Help Forum
Hotpoint TCM570G - Tumble Dryer belt tension pulley
Postby dnaxton » Sat May 28, 2011 3:47 pm
Good Afternoon All,
I am after a bit of advise
The tumble dryer belt tension pulley on my Hotpoint TCM570G has play in it and is rubbing against the bracket.
How easy are they to replace
Can someone point in the direct of the correct part as I can't find one in the shop section.
Dave
dnaxton
Regular Appliance Forum User
Re: Hotpoint TCM570G - Tumble Dryer belt tension pulley
Postby electrofix » Sat May 28, 2011 4:06 pm
should be part no C00113879
this is a condensor dryer so you have to remove the fan cover in front of the motor and remove the fan to get at the bolt holding pulley can be a bit tricky to fit since belt is elastic but if you fit back bolt first do not tighten just put in a few threads you can use the pulley as a lever to tention belt pulley then hooks into motor and you can tighten up
hope it helps plug out first
dave
electrofix
Postby dnaxton » Sat May 28, 2011 4:12 pm
Hi Dave
Thank you for the swift reply.
I was looking at that part number as the part looks indentical to the one on my machine. But it didn't state my model in the list
http://shop.ukwhitegoods.co.uk/Tumble+D ... ulley.html
I will get one ordered :wink:
Thanks for your help
Dave
dnaxton
Postby electrofix » Sat May 28, 2011 4:42 pm
nop prob m8 some of us saddies are still in work sat night lol
electrofix
In total there are 4 users online :: 0 registered, 0 hidden and 4 guests (based on users active over the past 30 minutes)
