Tumble Dryer Help Forum
Indesit ISL70C fault code
Postby blackpoolfox » Sun Apr 22, 2012 6:14 pm
Drier is turning on normally then after about 20 secs gives a beep, momentarily stops then starts running again with the power light flashing rapidly and the following lights blinking around once per sec - from left : time delay, alarm and empty water. The only light not flashing is the high heat light. If the drier is left to run in this state it continues to run but doesnt appear to get warm.
Any assistance appreciated, thanks.
blackpoolfox
Re: Indesit ISL70C fault code
Postby iadom » Sun Apr 22, 2012 6:53 pm
Always best to give the flashing lights by number from top to bottom or left to right.
Your error message is F13
Rear NTC open or short circuit.
Postby blackpoolfox » Sun Apr 22, 2012 7:25 pm
Ok from left - 1,2,4 are flashing once/sec and power light flashing rapidly.
Ok thanks any idea what kind of a job it is to fix this?
Many thanks.
blackpoolfox
Postby blackpoolfox » Sun Apr 22, 2012 7:35 pm
Could you please also advise where this part is located inside the drier?
Thanks.
blackpoolfox
Postby iadom » Sun Apr 22, 2012 7:54 pm
Err, at the rear, behind the small back panel.
The thermostats and NTC should be changed as a complete kit, two different types, one with a white NTC and one black.
I would also remove the condensor from the bottom of the machine at the front. This should be cleaned out every week or so, if it is badly clogged up then that will lead to stat/ntc failure.
Be sure to remove the mains plug before removing any panels.
Sent from my iPad using Tapatalk HD
Postby blackpoolfox » Mon Apr 23, 2012 7:46 pm
Ok we have taken the back off today, the 2 outer devices are black and the center one is white.
What would I actually be asking for as a replacement would it be called a rear NTC kit?
Also, are the 2 outer black devices the same, ie : does it matter which way around they go?
Many thanks.
blackpoolfox
Postby iadom » Mon Apr 23, 2012 9:12 pm
The thermostat kits come complete, they must be replaced in exactly the same position as the original ones.
If your serial number is 51130.0000 or less you need C00208298 HERE
If the serial number is 51130.0001 or higher you need kit C00208299.HERE
Postby blackpoolfox » Tue Apr 24, 2012 8:21 pm
Fitted replacement parts today and seems to have cleared the fault, many thanks for the info!
blackpoolfox
Postby iadom » Tue Apr 24, 2012 8:47 pm
8)
And if you are a Seasiders fan you are in the play offs as well. RESULT.
Postby blackpoolfox » Fri Apr 27, 2012 5:04 pm
Yeah indeed! good result 8)
blackpoolfox
Users browsing this forum: No registered users and 1 guest
In total there is 1 user online :: 0 registered, 0 hidden and 1 guest (based on users active over the past 30 minutes)
