My dryer has a problem.
No matter which programmes you select, the LCD display count down goes down to zero after roughly 3 mins. I called Neff and they advised that it could be the sensor.
I stripped it down, cleaned all excess fluff etc from filters, heat exchanger etc and replaced the sensor but it is still doing the same thing.
Is it the display PCB that is causing the problem or the main module to the right?
