Moderators: r600a, johnmac11, Jackal, Del, Dave_Conway, don, iadom, Penguin45, Dales-Electronic, dquinn
by rich123 » Mon Sep 11, 2006 4:10 pm
I have purchased a pair of new Dyson belts for my Dyson DC04 and have taken it all apart. When it came to the clutch I took off the yellow cap and removed the clutch complete. After removing 2 screws in the end I was able to replace the one belt situated at the end ok, but for the life of me I am unable to see how I am supposed to take the clutch apart in order to fit the belt round the white wheel in the centre.
Any advice would be very much apreciated before I throw the thing out of the window!!!
rich123
by Goatboy » Mon Sep 18, 2006 1:12 pm
rich123 wrote:but for the life of me I am unable to see how I am supposed to take the clutch apart in order to fit the belt round the white wheel in the centre.
Impossible I'm affraid
If that belt is damaged, then you need a new clutch!
Lancelot wrote:Despite your aspersions on my abilities... you're still my hero!
Goatboy
- Appliance Forum Veteran
by gegsy » Mon Sep 18, 2006 9:12 pm
Its pure evil to fit aswell
I would use the engineer link below to be fair
Greg
gegsy
by madrat » Wed Sep 20, 2006 12:36 am
I managed to fit a new clutch (well new to me got it of ebay) but it was a real bugger, the hardest thing was geting the casing back to gether you needed at least 4 hands some the size of a 1 year old.
took about 90 minutes to do it.
madrat
by Yank » Sun Sep 24, 2006 7:17 pm
Madrat/Gegsy,
I have a DC14 with a noisy clutch. Tried to figure out how to remove the outside know so I could pull clutch but no luck. How do you remove the clutch??
Yank
Yank
by madrat » Sun Sep 24, 2006 8:22 pm
As far as I can remember I removed the outer cassing (allan key things)and the clutch outer knob (the colourd bit by carfully prying it off) then ther was a bit of plastic covering the belt this was eather held on by the outer casing or 2 screws I cant remember now??? the cluth unit was held in with screws I remember that much. If yours has auto brush height thingy you have to pop the pivating bit off, it then snaps back into place. putting it back together is the hard part I did it in front of the TV while 8 legged freeks was on and it took me all that time to do it. Mine was a DCO4 so they might be differant.
madrat
by billsvacs » Mon Nov 06, 2006 5:59 pm
to fit the other belt you remove the plastic sticker on the other end of the clutch from the one you have fitted then you will see a circlip remove this and you will be able to srip the clutch and replace the belt if you can get one? then just reasemble the whole thing and refit the unit
hope this helps
regards
bill
bill's vacuum services
cornwall
billsvacs
Return to Vacuum Cleaner Help Forum
- Dyson DC04 throwing belt
by BGH » Mon Dec 12, 2005 8:40 pm
- 3155 Views
- Last post by dandandan
Wed May 26, 2010 10:32 am
- Dyson DC04 Belt Change - how do you stretch it that far
by invisiblesystem » Thu Mar 04, 2010 12:00 am
- 1275 Views
- Last post by kladave
Thu Mar 04, 2010 4:40 pm
- Dyson DC04 belt keeps coming off and suction low
by dandandan » Wed May 26, 2010 10:35 am
- 5 Replies
- 1592 Views
Wed May 26, 2010 1:08 pm
- dyson dc04 upright
by john10671 » Fri Jun 26, 2009 4:27 pm
- 1629 Views
- Last post by neon_3SP_glow
Tue Apr 20, 2010 5:51 pm
- Dyson DC04 - switch removal
by dkmulvey » Sat Sep 24, 2005 7:51 am
- 11 Replies
- 7447 Views
- Last post by legsthediver
Mon Apr 03, 2006 9:59 pm
