Spare Parts Help
glass door for Sheffield 1100 range cooker
If you are looking for a spares for your washing machine, dishwasher, fridge freezer of any other appliance or need help with a part post a request in this forum and we will help you or jump straight to the online spares store from this link
Spare parts for all domestic appliances
“Spare
Get spare parts including accessories and filters for your kitchen appliances in our store for all major makes and models including many low cost spares or contact us and we will find the parts for you
by Futureboy » Tue Jul 06, 2004 2:18 pm
Hi, does anyone know where I can get an inner glass oven door made to fit a Sheffield 1100 Range cooker ? This cooker was only made for a short time mid to late 90s, is extremely solid and well made, and was distributed by the Range Cooker Co. in Blackpool, (britannia) who have told me the part is no longer available.
I figured there could not be anything THAT special about oven door glass other than it having to be strong and extremely heat resistant, but I seem to be drawing a blank.
I repeat, I'm not looking for an original manufacturer replacement, as I've been told they are not available any more, just looking for a lead to a company that can make a suitable substitute.
Many thanks !
PT
Futureboy
 Oven & cooker door hinges
by Dave_Conway » Tue Jul 06, 2004 2:57 pm
A specialist glass supplier maybe ?
All oven door glass parts are made specifically for certain models and are supplied as such, in virtually every case we have no idea of the physical size etc from the service information supplied, so even the size wouldn't help identify a replecement I'm afraid.
Please be aware that inner oven door glass panels very often are "reflective glass" in that they reflect the heat inwards, they are not just toughened high temp panels.
There must be someone out there though that makes them, any ideas anyone ?
by Futureboy » Tue Jul 06, 2004 3:54 pm
Thanks Dave
Since my post I did a bit of net searching and confirmed what you say about the glass having to be heat reflective.
I also found the web site of a glass manufacturer who supplies the appliance manufacturers, as it were - www.schott.com but I doubt these people would be interested in an enquiry from joe public.
I can't imagine I am the only person to have had this problem. The cooker was bought just before Christmas 1998 so is just over 5 1/2 years old. It seems hard to believe that others have not had to replace oven glass in the past.
I've contacted numerous glass companies out of the Yellow pages, and of the 2 that do fire-resistant glass, neither could say for sure whether it was suitable for ovens; one said it was suitable for stoves, but I'm guessing that means it is far from reflective; in fact probably the complete opposite !
Best wishes
PT
Futureboy
by Martin » Tue Jul 06, 2004 4:02 pm
Futureboy,
I assume you have asked 'Corning Glass' who make most oven and ceramic hob glass (and sub contract under license to others) throughout the world (and the UK) also of course Pilkinton Glass :wink:
by kwatt » Tue Jul 06, 2004 4:03 pm
If memory serves me right there is legislation in place that states that a manufacturer must have spares available for certain period of time. It may well be worth contacting Trading Standards to see what they think of this.
by Penguin45 » Tue Jul 06, 2004 8:26 pm
7 yrs from date of cessation. The catch is "Suitable replacement part" - you may finish up with a an entire replacement door!
Dave, Martin and K (being older than I) will no doubt remember Hoover making the "small hole" drum pulley obsolete, and replacing it with an entire drum/pulley/backplate assembly. This was deemed to be a suitable replacement!
by Futureboy » Wed Jul 07, 2004 10:40 am
What a great idea from Kevin !
I wonder if the glass would be big enough though. The size is as follows:
60.5 cm high x 35.5 cm wide x just over 3mm thick
It's one of those types that rather than being inset into the door, is actually screwed to the door frame at it's four corners, so it's actually pretty much the same size as the door itself.
Thanks for all suggestions so far, much appreciated !
PT
Futureboy
by Futureboy » Sun Jul 18, 2004 1:29 pm
Hi again
It all seems to have gone quiet on the suggestions for replacement oven glass.
Was anyone able to verify whether the glass from the Whirlpool cookers was a suitable replacement ?
Failing that, I had the idea of maybe ordering the inner glass panel for another make of cooker - e.g. a Zanussi 90 cm SINGLE oven door range model, where the glass panel certainly would be large enough, and then getting it cut to size. Does anythone think this would be a bad idea ?
I contacted Schott glass, who put me on to a ditributor who quoted me almost £ 200 including delivery for a piece of glass cut to size, I think they called it cermaic glass, with a slight brown tint to it; but again, they were not able to tell me if it would be the same spec as the one I had.
To the gentleman who said I might have to buy a whole new door - if only I could ! They don't do those either.
I don't want to waste anyone's time so if I don't get any further joy, thanks to everyone for the suggestions so far.
PT
Futureboy
 Freezer flap or drawer front broken?
You can buy replacement plastic freezer flaps and drawer fronts in our store here to fit all popular makes including for built in and integrated models from Diplomat, Lamona, Beko, Hotpoint, Bosch and many more
Do check carefully when ordering flaps as although many look the same they may well not be, if you are unsure please email to ask for assistance and we'll find it for you
plastic freezer flaps and drawer fronts for most fridge freezers and freezers including built in and integrated from popular makes like Hoover, Zanussi, Smeg, Diplomat, Hygena and many more
Return to Spare Parts Help
 Oven & cooker switches
We supply switches and most other oven and cooker spare parts to the trade and public in our online spare parts store at terrific prices for all major brands including Smeg, Beko, Leisure, Stoves, Rangemaster, Britannia and many, many more
Shop online for
                        cooker and oven spare parts
