Australasian Appliance Forum
F&P Wash. Mach. M#GW708 - leaking from underneath machin
Postby keyse » Thu Dec 07, 2006 1:03 pm
Can anybody pleaaaase help? My fisher and paykel washing machine model number GW708 is leaking loads of water during the end of the washing cycle. I have checked the pipes at the back but nothing is leaking from there. The water appears to be coming from underneath the washing machine. Someone has suggested the filter pump may be blocked but I have no idea where it is on this machine. Any ideas greatly received. Also, I have lost my manual so can't even look in that!! Thank you ...
keyse
Re: F&P Wash. Mach. M#GW708 - leaking from underneath ma
Postby msappliance » Thu Dec 07, 2006 8:02 pm
Have a look around the door seal, sometimes on a spin water is forced in to small holes. Same applies to the outer drum it maybe cracked but make sure you unplug appliance before any work carried out.
mikenem
msappliance
Postby Penguin45 » Fri Dec 08, 2006 1:35 am
Rodney, you plonker......
Two primary leaks on this one:
1) Drain pump most likely candidate. Pump seal failed, replacement only option. Sealing ring for the pump to tub can also fail, allowing water to dribble out.
2) Drum bearing seal failure - water runs down the drive shaft and through the motor. Usually accompanied by increasing noise and occasional short circuits.
It's also possible that the drain hose is cracked or split, but I can't recall it being posted in this forum.
Long and short of it is that you're going to have to drag it out and tip it back to a good angle and see what's going on.
Stay safe - power off.
In total there are 2 users online :: 0 registered, 0 hidden and 2 guests (based on users active over the past 30 minutes)
