BOSCH EXXCEL SM56 ERROR CODE E:14
by stuy » Mon Sep 21, 2009 10:51 pm
HELLO,
I HAVE A BOSCH EXXCEL SM56 THAT GIVES AN ERROR CODE E:14 WHEN I TRY TO START THE WASH CYCLE, THE CHECK WATER LIGHT ALSO COME ON.
I HAVE CHECKED THE OBVIOUS WATER CONNECTIONS, FILTERS & WASTE AND ALL SEEM FINE, WATER DOES FLOW IN TO THE MACHINE AND THEN GETS PUMPED BACK OUT WHEN THE ERROR OCCURS SO BOTH PUMPS SEEM TO OPERATE FINE.
ANY SUGGESTIONS? Thanks.
stuy
 Do you need an dishwasher repair?
Find local approved dishwasher repair companies using our free search of hundreds of repairers to find approved companies in your area that will repair almost any dishwasher including built in and integrated dishwashers
“Find
by Penguin45 » Mon Sep 21, 2009 11:18 pm
Please post the full model number - SM56 doesn't come up. It should be etched into the top of the door inner panel; later machines have a label down the edge of the door.
by stuy » Tue Sep 22, 2009 2:11 am
Sorry! I'd given the wrong number all together!
Its: sms65e02gb
Thanks!
stuy
 Dishwasher spray arm broken?
If your dishwasher isn't washing as well as it should then your spray arms may be blocked or faulty resulting in the dishwasher not cleaning as it should. You can buy replacement spray arms and associated spare parts from our store to fit all major makes including AEG, Beko, Hotpoint, Smeg and many more
Do check carefully when ordering spray arms as while many may look the same they might well not be, if you are unsure please email to ask for assistance and we'll find it for you
spray arms for most dishwashers including popular makes like Hoover, Zanussi, Smeg, Diplomat, Bosch and many more
