Neff Dishwsher Spray Arms not rotating
by clivers » Sun Jun 12, 2011 10:51 am
Good morning...
I have a Neff 30 852 integrated dishwsher and neither the top or bottom spray arms are rotating during the wash process resulting in the contents remaining dirty. They are not stuck as I can manualy turn and spin them without any force and if I open the door during the cycle I can see that water is coming out of them. Is there anything I can check or replceto rectify this problem ?
Many thanks
Clivers
clivers
 Dishwasher not draining?
If your dishwasher will not drain the cause will often be that either the drain pump is blocked or faulty resulting in the dishwasher failing to empty. You can buy replacement drain pump including many low cost compatible dishwasher pumps in our store here to fit all major makes including AEG, Beko, Hotpoint, Smeg and many more
Drain pumps for most dishwashers including popular makes like Hoover, Zanussi, Smeg, Diplomat, LG and many more
by electrofix » Mon Jun 13, 2011 9:40 am
if its not a blockage its a motor problem
take both bars off. check for blocked jets and clean them out
fill and start machine without bars in and when motor starts let it run for 5 secs to push any rubbish through
replace bars and see what happens
if this fails you need professional help
Dave
electrofix
by clivers » Tue Jun 14, 2011 7:03 am
Morning
I ran the test as suggested and cleaned out the upper and ower arms. Unfortunately it did not make any improvement.
However, what I did notice was that when the spray arms were off and with the machine started, when I opened the door during the cycle the water was being pumped through the inlet at the bottom of the machine. Would this indicate that the motor is working as expected?
I have noticed that there is a lot of up and down movement in the lower spray arm when I put it back and wondered if it was worn, thus allowing the pressurised water to leak before it gets into the lower spray arms and the pipe work to the upper arm. :?:
Should there be any play in the dpray arms, and I coud not see any evidence of washers or seals, is this standard?
Many thanks :D
Clivers
clivers
by Martin » Tue Jun 14, 2011 11:25 am
clivers wrote:Should there be any play in the dpray arms, and I coud not see any evidence of washers or seals, is this standard?
The spray arms sound just fine so best eliminate any possibility on that score.
It would be handy though if you gave us the full model (ENr) number of your dishwasher at this stage 'cos there's a fair degree of variants out there in the wild. Most, whilst fully house trained, do have their differing little foibles. :wink:
by clivers » Tue Jun 14, 2011 8:37 pm
The E-Nr number is S5433X0GB/12
Clivers
clivers
by Martin » Wed Jun 15, 2011 7:43 am
clivers wrote:The E-Nr number is S5433X0GB/12
Just 3 likely causes then : -
1) Lack of water in tub
2) Circulating pump impellor blocked with debris
3) Circulating pump impellor split and broken
I would advise contacting a local engineer in to take a look for you. None of which are classed as a DIY fix by the way.
 Dishwasher not heating up water?
If your dishwasher will not heat the water the reason is often that the heater has failed, which is the heating element used to heat the water and to dry your dishes. You can buy replacement heating elements including many low cost compatible dishwasher heaters in our store here to fit all major makes including AEG, Beko, Smeg, Hotpoint, Bosch and many more
Heating elements for most dishwashers including popular makes like Hoover, Zanussi, Smeg, Diplomat, LG and many more
