Dishwasher Help Forum
DW686 IFT code
Forum to get help and advice on any dishwasher problems that you may have for full size, slimline dishwashers. For dishwasher spares click here
Get spare parts for dishwashers
Buy dishwasher spare parts in our store for all major dishwasher makes and models including many low cost compatible spares or contact us and we will find the parts you need for you
 Get Spare Parts Cheap
shop spare parts
by Procky69 » Wed Jun 14, 2017 3:42 pm
Afternoon all.
My DW686 Beko integrated dishwasher is only 4 years old and it sticks on the pumping hot water cycle shorting out the heating element before attempting to go again every 30seconds. The code I get on diagnostics is IFT (is this intermittent fault?). I have swapped the pump, synchronous valve and heater element individually but the same problem occurs. I have checked all pipes for blockages that I can access as it sounds as though it tries to pump water but nothing is coming through the spray arms. I've checked all those and they are clear. Is it an electrical short or pressure differential problem? It fills up and drains fine.
Thanks
User avatar
Procky69
Whitegoods Newbie
Whitegoods Newbie
 Dishwasher not draining?
If your dishwasher will not drain the cause will often be that either the drain pump is blocked or faulty resulting in the dishwasher failing to empty. You can buy replacement drain pump including many low cost compatible dishwasher pumps in our store here to fit all major makes including AEG, Beko, Hotpoint, Smeg and many more
Drain pumps for most dishwashers including popular makes like Hoover, Zanussi, Smeg, Diplomat, LG and many more
by Procky69 » Wed Jun 14, 2017 9:16 pm
It was the wires that run under the door hinge in a plastic sleeve. An earth and a black wire had been cut by the hinge causing a short in the sequence. Fixed and protected the rest of the wires from further damage. All works fine now, but be careful if you're doing it, as all the edges are sharp. Poor design, no wonder the wires were severed.
User avatar
Procky69
Whitegoods Newbie
Whitegoods Newbie
by pcanimal » Thu Oct 12, 2017 8:34 pm
Hi got a similar problem. Where abouts is the wire? Do you have Abby pics
User avatar
pcanimal
Whitegoods Newbie
Whitegoods Newbie
 Dishwasher spray arm broken?
If your dishwasher isn't washing as well as it should then your spray arms may be blocked or faulty resulting in the dishwasher not cleaning as it should. You can buy replacement spray arms and associated spare parts from our store to fit all major makes including AEG, Beko, Hotpoint, Smeg and many more
Do check carefully when ordering spray arms as while many may look the same they might well not be, if you are unsure please email to ask for assistance and we'll find it for you
spray arms for most dishwashers including popular makes like Hoover, Zanussi, Smeg, Diplomat, Bosch and many more
Return to Dishwasher Help Forum
http://www.ukwhitegoods.co.uk/
