Dishwasher Help Forum
Electrolux ESL6115 - Drains, does not fill. No error
Forum to get help and advice on any dishwasher problems that you may have for full size, slimline dishwashers. For dishwasher spares click here
Get spare parts for dishwashers
Buy dishwasher spare parts in our store for all major dishwasher makes and models including many low cost compatible spares or contact us and we will find the parts you need for you
 Support The Repair Community
Don't use an adblocker.
by easyeagle » Sat Jul 15, 2017 10:22 am
User Manual is here: http://www.usersmanualguide.com/manuals ... U26459.pdf
Workflow of issue:
1. Turn dishwasher on. End of programme indicator light flashes (normal - no programme set), nothing else occurs.
-Press programme selection / cancel button until desired programme (programme 2) LED lit.
-Close door.
2. All leds now off except for programme 2 LED (solid).
Drain pump operates for ~5s and stops.
No other operations occur. Nothing audible. Programme 2 LED remains lit indefinitely.
If the machine is switched off (whether using ON/OFF pushbutton or isolated) and on at this point, it resumes in the same state (Programme 2 LED lit), as in normal operation. Programme can be cancelled by pressing programme selection / cancel button for 5s until end of programme indicator light flashes - and we're back to step 1.
There's no visual or audible fault code, so I guess the dishwasher simply isn't detecting whatever criteria is needed to advance to the next step of the programme. Unfortunately I'm not sure what would be operating at this point. Is it likely to be trying to run the wash pump, or is there any other check before it starts that?
I've replaced the heater on this dishwasher before, so I know my way around the machine, but don't know the sequence of operation. Just like to know what I'm looking for before I begin the diagnostics!
Cheers!
User avatar
easyeagle
Whitegoods Newbie
Whitegoods Newbie
 Dishwasher not draining?
If your dishwasher will not drain the cause will often be that either the drain pump is blocked or faulty resulting in the dishwasher failing to empty. You can buy replacement drain pump including many low cost compatible dishwasher pumps in our store here to fit all major makes including AEG, Beko, Hotpoint, Smeg and many more
Drain pumps for most dishwashers including popular makes like Hoover, Zanussi, Smeg, Diplomat, LG and many more
by bazza500 » Sat Jul 15, 2017 6:03 pm
It sounds to me that your dishwasher is trying to calibrate the sensor.
Switch it on, start a program and then go and have a cup of tea. It will run in about 10-15 minutes.
bazza500
WTA Team Member
WTA Team Member
by easyeagle » Mon Jul 17, 2017 10:17 am
..is the right answer! That's embarrassing. But the type of embarrassment that involves no extra cost or effort is the best kind! Thanks very much for your help :)
User avatar
easyeagle
Whitegoods Newbie
Whitegoods Newbie
shop spare parts
Return to Dishwasher Help Forum
