Dishwasher Help Forum
Beko DFN05R10B Not Filling
Forum to get help and advice on any dishwasher problems that you may have for full size, slimline dishwashers. For dishwasher spares click here
Get spare parts for dishwashers
Buy dishwasher spare parts in our store for all major dishwasher makes and models including many low cost compatible spares or contact us and we will find the parts you need for you
by RustySkull » Thu Dec 07, 2017 5:07 pm
Good evening everybody,
I would like to ask for some assistance please because I'm having an issue with my 6 month old Dishwasher. It won't start a cycle, it's been fine but last night it wouldn't start a wash cycle. When you turn the knob to select the programme you want, the ON LED lights up, as normal. Then, when you press the start button the Wash LED lights up as normal but nothing happens, it sat for 15 minutes like this, no wash started, no water came in and the drain pump didn't do anything at the start.
To troubleshoot I've...
    Taken the filter out and checked for blockages in the well.
    Checked for water pressure in the fill supply.
    Removed the waste hose and checked for blockages.
    Removed the water pump to check for blockages.
    Checked the door switch and flood switch.
    Unplugged it for 1 hour.
    Tried to do a Factory Reset by holding the Start button for 5 seconds. (nothing happned).
Now I clean the filter after every wash, I'm also very sure there are no blockages in the drain side as I've had it apart, and I believe that would stop it from filling and
starting a cycle. Can any of you please suggest anything else to check? The inlet pipes all looked okey to me inside also... Is it common for the valve to go so early on in its life? Or are there some more simple things to check?
Any advice would be more than welcome, thank you :)
User avatar
RustySkull
Appliance Forum User
 Does your dishwasher need a new cutlery basket?
Get a replacement cutlery basket for your dishwasher in our store here including many low cost compatible baskets to fit all major makes including Smeg, Lamona, Beko, Hotpoint, Bosch and many more
Dishwasher cutlery baskets for most dishwashers including popular makes like Hoover, Zanussi, Smeg, Diplomat, Hygena and many more
by Seamy » Thu Dec 07, 2017 6:42 pm
Drain pump should run first, if its not running there could be a pump issue, either open circuit coil or supply to pump fault, it runs pump for about 30 secs, then fills with 4 litres, once 4 litres are detected to have passed through water counter (in 90 secs) it will initiate circulation pump. If it doesn't detect water coming in ( or slow to fill because of poor flow rate) it won't start washing.
User avatar
Seamy
Appliance Veteran
Appliance Veteran
by RustySkull » Sat Dec 09, 2017 9:00 pm
Yeah the drain pump doesn't seem to work. It's free and looks good when I removed it though. Doesn't matter now I wanted to fix it asap and their engineers couldn't get to me within 2 weeks, but now they're coming next week so time to make use of the Guarantee lol. √√√
User avatar
RustySkull
 Dishwasher leaking?
If your dishwasher is leaking one of the most common reasons is that a door seal is faulty allowing water to escape. You can buy replacement door seals in our store here to fit all major makes including Lamona, Beko, Hotpoint, Bosch and many more
Door seals for most dishwashers including popular makes like Hoover, Zanussi, Smeg, Diplomat, Hygena and many more
Return to Dishwasher Help Forum
