Error 63 - Bosch Logixx 8 Washing Machine
by nr84 » Tue Jul 17, 2007 7:33 pm
Cany anyone help identify this message? F:63 displayed on Bosch Logixx 8. It won't clear even when you've switched off at the mains then back on again. We've emptied it, taken the water out, sworn at it and all sorts...
HEEEELP!!
:x
nr84
by gegsy » Tue Jul 17, 2007 7:34 pm
Need the model number off the stainless steel of door please.
Greg
gegsy
by nr84 » Tue Jul 17, 2007 7:37 pm
Ah, think it's WAS32466GB - does that seem about right?
:oops:
nr84
by macmini » Tue Jul 17, 2007 8:38 pm
Are these not under two year old?
If so, they're still covered under your warranty, contact the retailer you bought from.
macmini
Valued Contributor
Valued Contributor
by nr84 » Tue Jul 17, 2007 8:39 pm
8O
Thanks for this - I think!
The last bit is /03 - wouldn't care but it's just out the wrapper - just installed yesterday - started it off and it filled with water then "hung" (sorry I'm an IT person!) - tried to reboot but to no avail...
Hopefully it's covered by warranty
Nicki
nr84
by gegsy » Tue Jul 17, 2007 9:08 pm
I would do as macmini says and return to retailer if its brand new as this has a fault, just one of those things :?
Greg
gegsy
by whitevanman » Tue Jul 17, 2007 9:18 pm
nr84 wrote:8O
Nicki
just a thought, if you didn't have a dishwasher before and you have fitted the drain hose under the sink , check that the end has been cut off.
Wvm
whitevanman
Valued Contributor
Valued Contributor
by superfix » Tue Jul 17, 2007 9:51 pm
I agree try removing drain hose from waste and placing it in a bucket. Then try to drain the m/c.
Otherwise you will more than likely face a call out charge if it's not the m/c that is faulty.
superfix
Valued Contributor
Valued Contributor
by gegsy » Tue Jul 17, 2007 10:03 pm
Wouldn't you get F13 for drain problem instead of F63 which is an error in the power module :con: :D
Greg
gegsy
by Penguin45 » Tue Jul 17, 2007 11:15 pm
Isn't it a washing machine, anyway?
by gegsy » Wed Jul 18, 2007 7:35 am
Penguin45 wrote:Isn't it a washing machine, anyway?
Yea :oops:, but fault code still stands :D
Greg
gegsy
by Martin » Wed Jul 18, 2007 7:41 am
gegsy wrote:Wouldn't you get F13 for drain problem instead of F63 which is an error in the power module
Hang on! I'll got to Trade Tech and look up 'Bosch error codes', I expect there's a list there somewhere....BRB! :wink:
by nr84 » Wed Jul 18, 2007 7:44 am
Hi, yes it's a washing machine...but I checked the drainage pipe anyway and it's okay. Hopefully we'll get someone out to fix it - or replace it - in the next day or two...the washing is piling up!
nr84
by gegsy » Wed Jul 18, 2007 8:10 am
:clown:
gegsy
 Washing machine door seal gaskets
If need a new door seal for your washing machine you can buy a replacement seal in our store here for all major washing machine brands with many low cost compatible seals available and many other washing machine spare parts. And for more detailed advice or support on how to replace a washing machine door gasket please see our fitting instructions here
A washing machine door seal or gasket, an important part in your washing machine
