Hotpoint Ultima TDC60P - Intermittent Heat Problem
by final_spin » Mon Sep 22, 2008 9:34 am
I have a Hotpoint TDC60P tumble-dryer which has worked fine for 6 years now. I'm now experiencing a problem.
The machine works fine from cold; produces heat & tumbles ok.
However, after about 3-4 minutes the Dryer light extinguishes & the machine loses heat, although it continues tumbling & reversing as usual.
I've purchased (although not yet fitted,) a pair of thermostats for the rear of the machine but I know that there is another 'stat fitted above the door.
Could this front exhaust thermostat be causing the heat fail problem?
If the machine is stopped & then restarted then occasionally the Dryer light will flicker on for a second or two.
Leaving the door open for a period of time & then restarting the machine often produces heat normally with the Dryer light illuminated - at least for a few minutes.
Any help would be appreciated here.
Many thanks.
final_spin
 No water into your washing machine?
If your washing does not fill up with water then it is likely that your water supply is faulty or the water fill valve in your machine is. Find replacement water valves in our store including many low cost compatible fill valves for all major brands such as Hoover, Hotpoint, Beko, AEG and more
Buy washing machine water valves and other washing machine spare parts
by iadom » Mon Sep 22, 2008 9:57 am
TBH the small stat above the door is often the cause of just such a problem, the main stats at the rear generally stop the machine from heating completely once the fail.
The dryness module can also fail but normally with the heater staying on all the time even when it should be off.
Door stat is a 1701575
Jim.
by final_spin » Mon Sep 22, 2008 10:14 am
Many thanks for your reply Jim.
I'll change the front 'stat to begin with & see if that solves the problem.
final_spin
by iadom » Mon Sep 22, 2008 10:19 am
Just hope its that or the main stats, the PCB is very expensive. :cry:
 Before you post it… search it!
Please, before you post and ask something that has been asked before (often many times) please use the search facilities available.
Here you can search the forums only, including trade forums with permissions
Here you can search the entire site including all articles, public forums and online store
Use the search function before you post!
