Indesit WIDL126 Flashing Lights
by philhuff » Sat Jun 13, 2009 11:58 am
Hi all,
I've searched through and failed to find an answer to my problem, so can anyone help out?
I've got an Indesit WIDL126. There appears to be no problems with the machine, and it's seemingly completing its wash cycles without incident. However, twice now it's flashed its lights at me, suggesting there's a problem.
All four LED's, all four Function lights, and the door lock light (so every light on the machine) flash very quickly and continuously. I've not found a list of error codes, so can anyone else shed some light on this?
Thanks in advance.
philhuff
 Washing machine door seal gaskets
If need a new door seal for your washing machine you can buy a replacement seal in our store here for all major washing machine brands with many low cost compatible seals available and many other washing machine spare parts. And for more detailed advice or support on how to replace a washing machine door gasket please see our fitting instructions here
A washing machine door seal or gasket, an important part in your washing machine
by iadom » Sat Jun 13, 2009 2:13 pm
Not a specific error code, its just an Indesit thats all, think yourself lucky its actually working at all.
All lights flashing usually means a main board failure. It could be loose connections on the PCB though.
by philhuff » Sat Jun 13, 2009 3:37 pm
iadom wrote:Not a specific error code, its just an Indesit thats all, think yourself lucky its actually working at all.
Ha! :lol:
I can't really argue with that. However, in fairness, this one was a Comet auction one that I picked up for about £100, and it's lasted four years or so, so I don't think it owes me much!
I've just turned it on again and now it's flashing the bottom LED and all four Function lights (it's not done that one before) so I'm guessing that it's basically screwed...
philhuff
by iadom » Sat Jun 13, 2009 4:30 pm
It would do no harm for you to try and tighten up the connections on the circuit boards, with the mains plug removed of course but it does sound as though the electronics are going pear shaped, very common on Indesit machines.
Really expensive to consider TBH.
4 years for £100 is very good going for one of these, you really need to spend £350 to £400 before you get into decent quality machines today.
 Washing machine carbon brushes
Did you know that carbon brushes are very often the cause of a washing machine drum not turning when they wear out? You can buy replacement carbon brushes including many low cost compatible washing machine carbons in our store here to fit all major washing machine makes including AEG, Beko, Hotpoint, Bosch and many more
Carbon brushes for most washing machines including popular makes like AEG, Hotpoint, Beko, Baumatic, Bosch and many more
