HOOVER OPH714 Error code E07.
by spud83 » Sun Feb 13, 2011 7:13 am
I have OPH 714 showing error code E07. The machine seems to have completed the cycle but will not release the door at the end if it is showing this error code.Any ideas?
Does your washing machine stink?
If your washing machine stinks, smells bad or emits strange odours it is most likely to be caused by bacteria build up in the washer. To clean this we recommend using Affresh that you can buy here to clean out the bacteria. And for more detailed advice on washing machine odour you can read our article all about smelly washing machines here
Buy Affresh washing machine cleaner here to stop bad smells from your washing machine
by Specialist01269 » Sun Feb 13, 2011 4:07 pm
Hi: E07 is listed as a faulty door interlock switch or Jammed motor, please remember:
POWER OFF & PLUG OUT BEFORE CHECKING. Getting :zap: can seriously spoil your day.
If you don't have the equipment or knowledge to safely check your machine, please call a good local engineer. You could try the UKWG repairs@ faciltiy to find an engineer local to you.
Let us fix it properly.
 Washing machine door seal gaskets
If need a new door seal for your washing machine you can buy a replacement seal in our store here for all major washing machine brands with many low cost compatible seals available and many other washing machine spare parts. And for more detailed advice or support on how to replace a washing machine door gasket please see our fitting instructions here
A washing machine door seal or gasket, an important part in your washing machine
