BEKO Tacho Magnet Needed!!!!
by redreloaded » Sat Jul 02, 2011 12:22 pm
Afternoon all,
As a result of a previous post I was helped to successfully diagnose the fault with my machine which turned out to be a shattered tacho magnet, excellent I thought a quick fix, until trying to get hold of one of the little buggers.
Its not the tacho coil I'm after, which seam to be widely available but the actual tacho magnet that fits to the end of the drive shaft of the motor, I cant seam to find one anywhere! So I wondered if anyone has an idea where I may be able to get this else it will have to be a whole new motor.
Its for a BEKO WM5120W washing machine.
Many thanks,
Steve
redreloaded
 Washing machine carbon brushes
Did you know that carbon brushes are very often the cause of a washing machine drum not turning when they wear out? You can buy replacement carbon brushes including many low cost compatible washing machine carbons in our store here to fit all major washing machine makes including AEG, Beko, Hotpoint, Bosch and many more
Carbon brushes for most washing machines including popular makes like AEG, Hotpoint, Beko, Baumatic, Bosch and many more
by electrofix » Sat Jul 02, 2011 4:38 pm
as far as i am aware complete motor only
have not found another one that will fit yet unless someone else knows better
Dave
electrofix
by washtronics » Sat Jul 02, 2011 5:17 pm
i phoned qualtex that contacted beko and they said it is available as a spare part
washtronics
Valued Contributor
Valued Contributor
by electrofix » Sat Jul 02, 2011 5:58 pm
i hope you are right Washtronics
but Qualtex dont list it connect dont list and the Beko tech site says noting about the magnet only the coil
one long shot if anybody has both motors lying around
hoover list a tacho magnet for performa and quatro range will it fit? even if shimmed and glued?
as i say its a long shot but it needs to be tried
Dave
electrofix
by odom » Sat Jul 02, 2011 11:31 pm
Easiest and cheapest way is to go down to your local dump, bound to be a couple of Beko machines there. Pay one of the blokes £10, take the machine, get the magnet off then get your £10 back by taking the machine (with the motor separated) to a scrap metal merchant.
odom
Valued Contributor
Valued Contributor
by Martin » Sun Jul 03, 2011 5:12 pm
BEKO-DUMP-MAGNET.......how true, how appropriate.
by electrofix » Mon Jul 04, 2011 8:35 am
@ Martin
:D
Dave
electrofix
by jackalltrades » Thu May 31, 2012 7:49 am
Thanks to this and a previous post, i managed to trace the fault to the broken tacho magnet.
As they're not available, I've glued the magnet together onto the motor shaft with two part epoxy metal. Still working. So far so good!
jackalltrades
