Washing Machine Help Forum
Blomberg wnf6341 not spinning
This forum is for support, help and questions you have about washing machines and washer dryers. For washing machine spares click here
Get spare parts for washing machines
Buy washing machine spare parts in our store for all major washing machine makes and models including many low cost compatible spares or contact us and we will find the parts you need for you
by Bobbuild » Thu Apr 20, 2017 7:11 pm
Hi, I have a Blomberg wnf6341 which has suddenly decided it doesn't want to spin, no warning signs. Everything else works ok, wash cycle gets to spin and then it pumps, stops for a few minutes, pumps again and repeats. Any advice appreciated.
User avatar
Bobbuild
Appliance Forum User
 Support The Repair Community
Don't use an adblocker.
by electrofix » Thu Apr 20, 2017 7:17 pm
1 make sure spin is switched on
2 try to make it spin with no washing in
most times if a machine will spin empty it will just be an out of balance load
dave
User avatar
electrofix
Appliance Forum Moderator
by Bobbuild » Fri Apr 21, 2017 6:55 am
Hi Dave,
Tried both your suggestions already. I believe the spin won't operate if there is still water in the machine, I can see what looks like an air pressure switch at the front of the machine with a rubber hose running down to the bottom. I've disconnected this and checked it isn't blocked. There is no water in the machine, checked pump filter and emergency drain hose. Any other ideas?
User avatar
Bobbuild
by electrofix » Fri Apr 21, 2017 9:12 am
your right it wont spin if there is water in the machine or if it thinks there as water in the machine so the pressure switch may be faulty
does it try to start to spin ie turn slowly then tris to speed up and stops
Dave
User avatar
electrofix
by Bobbuild » Fri Apr 21, 2017 5:14 pm
No, if you put it on spin all that happens is the pump runs for a few seconds and then stops. After a minute or so it pumps again and so on, no drum movement at all.
User avatar
Bobbuild
by electrofix » Fri Apr 21, 2017 6:15 pm
if you put the machine on a wash cycle
1 does the drum turn
2 if yes does it turn both ways ?
Dave
User avatar
electrofix
by Bobbuild » Fri Apr 21, 2017 7:59 pm
Yes, it washes normally. Drum turns both ways.
User avatar
Bobbuild
by kwatt » Fri Apr 21, 2017 10:54 pm
Brushes worn down? Possible and it does appear to use a brushed motor according to the tech on it.
K.
"Sometimes you get the best light from a burning bridge" Don Henley
Cheap appliance spare parts in our store Find an appliance repair company here
User avatar
kwatt
Appliance Forum Administrator
by Bobbuild » Sat Apr 22, 2017 11:28 am
Spot on, managed to get a local guy to look at it. New brushes fitted, good as new. Hopefully. Thanks for your help and advice.
User avatar
Bobbuild
 Washing machine drum paddles
Broken drum paddles or lifters are often a fairly easy part to replace yourself and you can buy replacement drum paddles including many low cost compatible washing machine paddles in our store to fit all major washing machine makes including AEG, Beko, Hotpoint, Bosch and many more
“Drum
Return to Washing Machine Help Forum
