Washing Machine Help Forum
Zanussi ZWH7162J stops during cycle, shows E3A error code
This forum is for support, help and questions you have about washing machines and washer dryers. For washing machine spares click here
Get spare parts for washing machines
Buy washing machine spare parts in our store for all major washing machine makes and models including many low cost compatible spares or contact us and we will find the parts you need for you
shop spare parts
by Finnbob3334 » Tue Sep 12, 2017 9:01 pm
Hello,
I am currently having an issue with my Zanussi ZWH7162J washing machine. Especially at the higher temperature settings (90 and 60 degrees), the machine will stop mid cycle, not completing the cycle, the door will stay locked and the timer will reset, but this does not occur as often on the lower temperature settings. It will often take 2 or 3 attempts to get the machine to perform the complete cycle. I have checked the machine for error codes as detailed on the site and it comes up with the code E3A, which seems to point to a faulty PCB. Are there any other diagnostic tests I can try, and if it is a faulty PCB, is it relatively straightforward to replace?
Thank you for your help in advance,
Finn
User avatar
Finnbob3334
Whitegoods Newbie
Whitegoods Newbie
 Support The Repair Community
Don't use an adblocker.
by electrofix » Tue Sep 12, 2017 9:14 pm
E3A: Problems with “Sensing” circuit of the heating element relay
now you say it seems to be worse with higher temps
I would check
1 heater for earth faults
2 look for bad solder joints in the heater relay on the main pcb
Dave
User avatar
electrofix
Appliance Forum Moderator
by Finnbob3334 » Wed Sep 13, 2017 5:00 pm
Hello,
I am just wondering what the best way to check for heater earth faults would be. Can I do it with a standard multimeter or would I need more sophisticated equipment?
Thank you for your help,
Finn
User avatar
Finnbob3334
Whitegoods Newbie
Whitegoods Newbie
 Do you need an appliance repair?
Find local approved washing machine repair companies using our free search to find approved companies in your area from our database of hundreds that will repair almost any broken washing machine and help support the people that offer help for free
“Find
Return to Washing Machine Help Forum
