Washing Machine Help Forum
Zanussi Washing machine
This forum is for support, help and questions you have about washing machines and washer dryers. For washing machine spares click here
Get spare parts for washing machines
Buy washing machine spare parts in our store for all major washing machine makes and models including many low cost compatible spares or contact us and we will find the parts you need for you
by wyndaff » Fri Jan 12, 2018 10:45 am
Hi,
My first post, be gentle.
I have a I have a Zanussi electrolux aqaucycle essential 1600 6kg ZWF 1621W.
The drum spins really smooth. Very little friction, and minimal noise, by hand, but
on a cycle it's a monster.
The drum itself seems to have a lot of play, in all 3 axis's. It's a bit floppy in there. Waggles about if you like.
I've got the lid off and can see the two top springs.
I'm hesitant to dive straight in for a bearing change.
Can these springs stretch or maybe has the bottom one come adrift ?
Its eight years old, but i'm a single bloke, so it hasn't been stressed much.
I'm an electrical maintenance engineer by trade on 3Phase motors, but know little to nothing about domestic kit.
I'm kinda hoping you guys can give me a few pointers ?
Many thanks for any help.
Wyndaff
User avatar
wyndaff
Whitegoods Newbie
Whitegoods Newbie
 Washing machine door seal gaskets
If need a new door seal for your washing machine you can buy a replacement seal in our store here for all major washing machine brands with many low cost compatible seals available and many other washing machine spare parts. And for more detailed advice or support on how to replace a washing machine door gasket please see our fitting instructions here
A washing machine door seal or gasket, an important part in your washing machine
by iadom » Fri Jan 12, 2018 11:24 am
The likeliest possibility given your description and the fact that it has had light use, possibly nearly all at low temperature is that the drum support has snapped.
A massive job on some models and a completely uneconomic total drum change on others.
Would need the Pnc or product number from inside the door to check if yours has a sealed drum or not.
Unless you can see if the outer drum is in two halves secured by lots of screws or has a welded seam.
Pnc number begins with 914******
Nothing really matters much, and hardly anything really matters at all.
User avatar
iadom
Appliance Forum Moderator
by wyndaff » Fri Jan 12, 2018 12:17 pm
Thanks for such a swift response.
It's only ever been on 40° short spin.
I will get the PNC No. When I get in tonight. I'm fairly sure the drum splits, again, I'll have a look tonight.
Many thanks
Wyndaff
User avatar
wyndaff
Whitegoods Newbie
Whitegoods Newbie
by wyndaff » Fri Jan 12, 2018 5:16 pm
PNC No. 914791320
Drum splits with lots of 10mm bolts.
User avatar
wyndaff
Whitegoods Newbie
Whitegoods Newbie
by electrofix » Fri Jan 12, 2018 5:39 pm
drum spider part number 50283680002 also by the look of the way its mounted you might need bolts as well if they snap
I would email the shop for a price but don't buy it until you have stripped the machine and diagnosed it properly
think about replacing at least the drum bearing shaft seal and possibly the bearings as well while you have it stripped as the unit was made in 2005
Dave
User avatar
electrofix
by wyndaff » Fri Jan 12, 2018 6:37 pm
Top man. I will strip it down now.
Your spot on about the bearings. May as well.
Thank you ever so much for your help guys.
I will email the shop later on.
User avatar
wyndaff
Whitegoods Newbie
Whitegoods Newbie
by iadom » Fri Jan 12, 2018 7:35 pm
If the alloy drum support has corroded or fractured then a read of THIS article will help you to understand why I mentioned the constant low temperature washes that can lead to this type of failure.
Here is an example, this one was from a high quality, German made AEG machine as well. :(
User avatar
iadom
 Washing machine drum paddles
Broken drum paddles or lifters are often a fairly easy part to replace yourself and you can buy replacement drum paddles including many low cost compatible washing machine paddles in our store to fit all major washing machine makes including AEG, Beko, Hotpoint, Bosch and many more
“Drum
Return to Washing Machine Help Forum
http://www.ukwhitegoods.co.uk/
