New World oven not working
by eToucan » Wed Mar 29, 2006 9:51 am
Hi. I have a New World Image 1000 electric double oven with grill and ceramic hob. Model no. 016924. Serial no. 91055114. I guess it's about three years old.
The left hand oven no longer works. I'm no electrician by any measure, but I've circuit tested the heating element and this seems OK. I've had the back off the oven and tested what looks like the thermostat. Again OK.
I'm at a loss as to what to do next. Do you good people have any ideas or is it engineer time?
Thanks in advance.
 Cooker hood switches and control boards
You can buy replacement cooker hood switches or control modules including in our store to fit all major cooker hood makes such as Diplomat, AEG, Bosch, Lamona, Elica and many more
                     and electronic control modules for most cooker hoods including popular makes like AEG, Hotpoint,
                     Indesit, Ikea, Smeg and many more
by Whoppo » Wed Mar 29, 2006 3:28 pm
Power down/disconnect prior to any testing
Any testing you do with a multimeter should be ohms only
1) I dont recognise the model code as being a stoves newworld type, and looking at the serial number, its probably more than 10 years old, so that would make it a Merloni NewWorld
most oven circuits comprise of
terminal block --->
thermal cut out --->
clock ---> (if that oven is able to use an automatic START/STOP setting)
thermostat/selector switches --->
sometimes a pcb
elements --->
terminal block
most likely component, if you have ruled out the element and thermostat would be the clock, failing that the thermal cut out
maybe its time for you to call out an engineer, clocks can be expensive, however they can often have their automatic switching bypassed, leaving the cooker pemantly in manual
Regular Forum User
Regular Forum User
 Oven & cooker door hinges
