Problems with Diplomat Range 850 ADP 5426
 Oven & cooker switches
We supply switches and most other oven and cooker spare parts to the trade and public in our online spare parts store at terrific prices for all major brands including Smeg, Beko, Leisure, Stoves, Rangemaster, Britannia and many, many more
Shop online for
                        cooker and oven spare parts
by RoniB » Tue Jul 17, 2007 9:43 am
We have just moved into a new house and inherited a Diplomat Range 850 cooker. There seems to be a couple problems with it :
1. The top oven is always warm even when the switch is off.
2. The griddle is not working. I was wondering if this was something to do with the cut-off switch but the red light also fails to come on.
Just wondering if anyone else has had these problems and managed to fix them before I call someone out.
Thanks.
RoniB
 Oven & cooker door hinges
by damonsbeads » Tue Jul 17, 2007 2:29 pm
Hi, not really sure as mine seems to be working ok so far - would just love to know how to set the clock!!!
damonsbeads
by RoniB » Tue Jul 17, 2007 3:43 pm
Hi Damonsbeads,
To set the clock you press the second button (that looks like a cooking pot) and the third button (a pot with a line through it) simultaneously, and keep them depressed. Then use the plus and minus buttons to set the time of day. The A symbol should go off and the cookpot symbol comes on.
Hope this helps....
RoniB
by damonsbeads » Tue Jul 17, 2007 6:13 pm
Thanks, thats great! :D
damonsbeads
by Tim Wright » Sun Jan 24, 2016 3:25 pm
This thread was hijacked, but if anyone can answer OP's 2007 question there are quite a few people with the same problem who would like to know the answer.
Curiously, my stove has exactly the same combination fault - upper oven on all the time, griddle not working.
Tim Wright
by JohnnyBoy83 » Wed Jan 27, 2016 11:15 am
I had a similar problem with the top oven and i tried to fix it myself. I checked the switch at first but it was working properly. I couldn't find the issue so i called an electrician. The guy said that indeed, the switch was the problem as it didn't close cut the circuit well enough and a small amount of electricity was actually reaching the heaters. He changed the switch and the oven works fine now.
if i were you I would call a professional as there is a risk of fire in that case and when you add the grease inside the oven, this could cause some really bad problems.
JohnnyBoy83
 Is your oven not heating up?
Should your oven not heat up then there is a good chance that the fan heating element has failed. Find a new one in our store including many low cost compatible heating elements for all major brands and we will support you in finding the element you need but also check thermostats including any safety thermostats that many modern ovens and cookers have fitted
Buy Fan oven elements and other heating elements for built in ovens and cookers online
