Cooker And Oven Forum
Hotpoint EW91 Halogen Double Oven - repairs advice
This forum is for any cooking appliances that you need help with like cookers, ovens, hobs, hoods & microwaves. For cooker and oven spares click here
Get oven and cooker spare parts
Buy spare parts in our store for built in ones and cookers including range cookers with many low cost compatible spares available or contact us and we will find the parts you need for you
shop spare parts
by cfam » Mon Feb 12, 2018 10:16 pm
Looking for spare parts for Hotpoint EW91. Two faults so far:
1. The upper left and lower left electric rings no longer respond to the temperature control dials. I assume that a temperature regulator has failed. Can these be replaced?
2. The solar grill element also does not respond to the temperature control. Can this be replaced also?
Thanks in advance.
CFAM.
User avatar
cfam
Appliance Forum User
 Oven & cooker door hinges
If the door on your built in oven or cooker isn’t closing properly it’s almost certain that the door hinges will need to be replaced. Find replacement door hinges in our store for all major brands including Hotpoint, Britannia, Beko, Rosieres, Stoves, Smeg and many more
Buy oven door hinges for built in ovens and cookers online
by electrofix » Mon Feb 12, 2018 10:36 pm
basically 2 controls
yes they can be replaced
suggest you message the site shop with all model and serial and ask
https://shop.ukwhitegoods.co.uk/
I put the model in but a number of option come up so it needs to be looked up on the manufacturers service info
Dave
User avatar
electrofix
Appliance Forum Moderator
by cfam » Tue Feb 13, 2018 7:02 pm
Dave,
Thank you for your advice. Just received the serial number so I'll head over to the shop.
Regards,
CFAM
User avatar
cfam
by iadom » Tue Feb 13, 2018 10:47 pm
All parts the same across all three model variants.
To identify it would be better to say which controls you think are faulty rather than upper left and lower left rings.
Give us the controls by number from left to right that you suspect are at fault.
Does the solar grill element come on at all ?
Using the attached picture may be of help in identifying the three regulators you need.
Not the easiest of jobs, both sides have to come off and the complete hob has to be loosened and moved out of the way as well as all the knobs etc.
Please submit your questions in the relevant forum. Unsolicited PM's and emails will not be answered.
User avatar
iadom
by cfam » Sun Feb 18, 2018 3:15 pm
Hello Dave, Iadom,
Thank you for the picture, this was supplied separately by the shop staff. The controls I believe are at fault are positioned 1 and 2 from the left. With this information, the shop staff have supplied compatible parts, which I have received and I am now attempting to install. However, the pins seem to be different.
part supplied for control 1 https://shop.ukwhitegoods.co.uk/ele4123 ... -regulator
For control 1 (image attached), assuming this is the right part, I have labelled with arrows where I think the pin positions in the new component (left) relate to the old component (right). The connection for the red wiring appears straight-forward but the black wires it is not obvious. On the old component the position is labelled 4A but there is no equivalent position on the new component.
part supplied for control 2 (dual regulator) https://shop.ukwhitegoods.co.uk/cs146-c ... -regulator.
For control 2 (image attached) again I have labelled with arrows where I think the pin positions transfer across from the old (left) and the new (right) components.
So my questions are:
(a) have I got the right parts
(b) have transferred the pins across correctly.
Additional information:
The serial number for the cooker is 88 1 000 43.
I've parked the issue of the grill for the moment.
Any thoughts?
Regards,
CFAM.
control 2
control 1
User avatar
cfam
by electrofix » Sun Feb 18, 2018 4:51 pm
the contact numbers need to be seen to be certain and I can make them out from these photos clearly
Dave
User avatar
electrofix
by cfam » Sun Feb 18, 2018 5:49 pm
Hello Dave,
Thank you for your reply. I have uploaded the photos again highlighting the contact numbers. For clarity I've removed my arrow labels.
Regards,
CFAM
control 2 - labelled contact points
control1 - labelled contact points
User avatar
cfam
by cfam » Sun Feb 18, 2018 5:57 pm
In case these images are not clear then higher resolution images can be downloaded from my dropbox using the links below:
https://www.dropbox.com/s/evj9aowuis5uh ... d.jpg?dl=0
https://www.dropbox.com/s/d7lpb9qz699z0 ... d.jpg?dl=0
User avatar
cfam
by electrofix » Sun Feb 18, 2018 7:36 pm
no probs as far as I can see just match numbers
top one number for number
bottom one match numbers apart from both leads from 4A go on 4
Dave
User avatar
electrofix
by cfam » Mon Feb 19, 2018 1:49 am
Hello Dave,
Thank you for your guidance. I have installed control 2, as this was straight-forward. But control 1 requires crimping the two black leads together and I don't have the right tool with me so I've had to leave this for the time being. A bit of pain putting the whole cooker back together though. The new control 2 unit appears to be working fine. Once the cooker was back together I looked at the problem with the grill.
Using the diagram provided by Iadom, the control for the grill is the first one from the right (I'll call this control R1). I asked my Mother to show me what she does to switch on the grill. This involved switching on the main oven for a couple of minutes then switching it off then switching on the grill. I noted that the solar grill elements had a slow oscillating glow, i.e., they would heat-up then cool down. This was the same for both the dual and single side settings. This suggests to me that the regulator needs replacing. I have captured the problem on camera but will have to post a link sometime tomorrow.
Any thoughts?
Regards,
CFAM.
User avatar
cfam
by electrofix » Mon Feb 19, 2018 9:37 am
you should not need to operate oven first to use the grill
turn the grill control to its highest setting and see what happens
these controls work on time so for example half heat will do the following
lets say a time cycle is 10 sec so the unit turn the element on for 5 secs and off for 5. full power is permanently on and lower temp just alter the ratio. As the control wears it may go out of calibration and not turn on enough. One of the ways you can tell is try turning the grill control slowly on and listen carefully for the click as the contact operates. it should click before it reaches the first number otherwise it wont turn on early enough
https://www.altecautomotive.co.uk/635mm ... 3850-p.asp
Dave
User avatar
electrofix
 Is your oven not heating up?
Should your oven not heat up then there is a good chance that the fan heating element has failed. Find a new one in our store including many low cost compatible heating elements for all major brands and we will support you in finding the element you need but also check thermostats including any safety thermostats that many modern ovens and cookers have fitted
Buy Fan oven elements and other heating elements for built in ovens and cookers online
Return to Cooker And Oven Forum
 Oven & cooker switches
We supply switches and most other oven and cooker spare parts to the trade and public in our online spare parts store at terrific prices for all major brands including Smeg, Beko, Leisure, Stoves, Rangemaster, Britannia and many, many more
Shop online for
                        cooker and oven spare parts
