Tumble Dryer Help Forum
Hotpoint thumble dryer thermostate issue
Help and support for vented, condenser and heat pump tumble dryers. For tumble dryer spares click here
Get tumble dryer spare parts
Buy tumble dryer spare parts in our store for all tumble dryer makes and models including many low cost compatible spares or contact us and we will find the parts you need for you
 Get Spare Parts Cheap
shop spare parts
by csavarka » Wed Sep 13, 2017 4:55 pm
I have a hotpoint TDWSF 83B EP thumble dryer with a fault code F04.
I have check online and i found that is a thermostat issue.
So I have taken apart and tried to test the thermostat the NFC is works fine but the other one the stats I have tested resistance but nothing happens not even for the continuity.
So any other way to test or how I need to test correctly?
Finally where I can buy new if that one is not good ?
Regards Tamas
User avatar
csavarka
Whitegoods Newbie
Whitegoods Newbie
by iadom » Wed Sep 13, 2017 9:02 pm
This is a Whirlpool dryer rebadged as Hotpoint. The parts diagrams for these are not very clear but it appears that the heater and thermostats come as a complete assembly, list price £83.50. :(
There is also another ntc that appears to be located in the front fan housing.
Nothing really matters much, and hardly anything really matters at all.
User avatar
iadom
Appliance Forum Moderator
by csavarka » Thu Sep 14, 2017 7:36 pm
the state thermostat how I can test correctly ?
can I change for a resettable ?
Regards
User avatar
csavarka
Whitegoods Newbie
Whitegoods Newbie
by iadom » Thu Sep 14, 2017 7:45 pm
Not familiar with this Whirlpool dryer, where is this thermostat located, is it near the heating element. Fitting a stat of a different rating or a resettable one is not a wise thing to do.
If it is a thermostat and not an ntc then a simple continuity test is all that is required.
User avatar
iadom
 Support The Repair Community
Don't use an adblocker.
Return to Tumble Dryer Help Forum
cron
http://www.ukwhitegoods.co.uk/
