Tumble Dryer Help Forum
Code F-17 on Bosch WVD24520GB/01 washer-dryer
Help and support for vented, condenser and heat pump tumble dryers. For tumble dryer spares click here
Get tumble dryer spare parts
Buy tumble dryer spare parts in our store for all tumble dryer makes and models including many low cost compatible spares or contact us and we will find the parts you need for you
 Get Spare Parts Cheap
shop spare parts
by r-morris » Fri Jan 12, 2018 8:37 pm
Hi,
I know we all hate these machines but in a 1-bed flat space is at an absolute premium...
Washing programmes run perfectly.
Dryer programme generates code F-17 a couple of minutes in. This means a water supply problem, and the most common fix is to replace the inlet valve. However in this machine water can be observed entering the condenser reservoir so the valve is definitely OK; I have inspected the tubes and they are free of debris.
The fan and heater appear to be functioning. I would imagine it's a sensor issue, but although I've fixed quite a few washing machines I quite honestly don't know what to do with this dryer :-(
Any suggestions?
Thanks in advance for any replies :-)
User avatar
r-morris
Whitegoods Newbie
Whitegoods Newbie
by r-morris » Fri Jan 12, 2018 8:41 pm
Also, does anyone know what the purpose of this box is? The smaller diameter tube comes from the inlet valve, and the larger tube goes on to the condenser. There's a small hole in the top (air inlet I assume?)
User avatar
r-morris
Whitegoods Newbie
Whitegoods Newbie
by electrofix » Fri Jan 12, 2018 9:26 pm
all water entering any appliance has to go through an air break to pass water regs
if water supply to building got damaged there may be a vacuum in the pipes. without the air break it could be possible to suck dirty water back into a clean water main
Dave
User avatar
electrofix
Appliance Forum Moderator
by r-morris » Sat Jan 13, 2018 7:51 pm
Thanks for the reply Dave - makes sense, but what about the other water inlets, that go to the detergent drawer?
Any ideas on the F-17 error? Curiously, I've now discovered that if you use a wash+dry programme the drying works! But a separate drying programme always gives the error.
User avatar
r-morris
Whitegoods Newbie
Whitegoods Newbie
by electrofix » Sat Jan 13, 2018 8:01 pm
bosch withhold all codes so we only have what we can scrounge or work out most of the time
http://www.ukwhitegoods.co.uk/help/faul ... mitstart=0
you could look here but your range is not listed but I believe some of the bosch washer dryers are made by Smeg
Dave
User avatar
electrofix
 Tumble dryer drive belt broken?
If your tumble dryer drum does not turn then it is likely that the drive belt in your dryer has snapped or broken. Find a new drive belt in our store including many low cost compatible drive belts for all major brands including Hoover, Hotpoint, AEG, Beko, White Knight and many more
Buy tumble dryer drive belts and other tumble dryer spare parts
Return to Tumble Dryer Help Forum
