Fridge And Freezer Forum
Beko F/F Relay clicking compressor off??
Use this forum for help and advice for fridges, freezers and fridge freezers. For fridge and freezer spares please click here
UK Whitegoods for fridge and freezer spare parts
Buy spare parts in our store for fridges and freezers including built in with many low cost compatible spares available or contact us and we will find the parts you need for you
 Support The Repair Community
Don't use an adblocker.
by Nukeboy » Thu Feb 16, 2017 6:09 pm
Hello, My Beko F/F has stopped working. Compressor kicks in for 5 seconds then the relay or something clicks it off. This does it on a cycle every 3-4 mins.
Could it be the relay needs replacing.
Beko model is GENV220S
User avatar
Nukeboy
Appliance Forum User
 Get fridge water filters
You can buy replacement fridge water filters including many low cost compatible water filters in our store here for all major fridge freezer makes including American fridge freezers as well as built in and integrated models from Samsung, Hotpoint, LG, Liebherr, Maytag, Whirlpool and many more
Fridge water filters with free Timestrip for all fridge freezers including popular makes like Samsung, LG, Liebherr, Maytag, Whirlpool and many more
by Nukeboy » Thu Feb 16, 2017 7:28 pm
Pretty sure it is the PTC Relay
Beko PTC Relay 8EA 19E61 Is the part I need, but now they are no longer available. Anyone know of any alternatives that would fit my model?
This is what I need but can't find one anywhere.
http://www.bekospares.co.uk/ptc-relay-8 ... =8EA19E61#
User avatar
Nukeboy
by SAMURI » Fri Feb 17, 2017 10:29 am
It is more likely to be the compressor faulty not a cheap repair.
Bob
User avatar
SAMURI
WTA Member
WTA Member
by Nukeboy » Sun Feb 19, 2017 4:32 pm
Ok thanks.
I am hoping to try the cheaper route first by buying a Relay. Just cannot find a part that will fit
User avatar
Nukeboy
by SAMURI » Sun Feb 19, 2017 8:47 pm
If the compressor runs for a short time it will not be the relay.
If the relay was faulty it would not run or make any noise.
It runs for a short time then cuts out after a few seconds as the compressor is drawing too much current and then cuts out on the thermal cut out above the relay.
If you have a fault with the cut out or relay then the compressor will not run.
You can get universal relays but I would save your money as it will be the compressor faulty and if the new relay did work and run this would be short lived as it would weaken the thermal cut out and fail again.
You will find if you leave it on and it keeps running the compressor for a short time it will get Hot due to the windings overheating.
This shows it is getting power from the relay.
Bob
User avatar
SAMURI
WTA Member
WTA Member
by Nukeboy » Mon Feb 20, 2017 6:43 pm
Ok many thanks for your Reply.
I think I will take your advice and buy a new compressor.
Are they Easy to fit by a reasonably mechanically minded
Person. I.e. Myself?
User avatar
Nukeboy
by Lawrence » Mon Feb 20, 2017 9:59 pm
Nukeboy wrote:Are they Easy to fit by a reasonably mechanically minded Person. I.e. Myself?
In a word no, you would need to find a local refrigeration engineer .
It is a specialised job that requires specialised tools
User avatar
Lawrence
WTA Team Member
WTA Team Member
by Nukeboy » Wed Feb 22, 2017 1:05 pm
Ok thanks. I have been quoted £500. Does that's sound about right?
User avatar
Nukeboy
by Neil1987 » Thu Jun 15, 2017 11:17 pm
I need the exact relay for my beko fridge freezer!!! Did you find one? My compressor makes no noise at all when turned on all I here after five seconds of power is the relay click? Then the compressor just gets hot??? Is it the relay or the compressor
User avatar
Neil1987
Whitegoods Newbie
Whitegoods Newbie
by kwatt » Thu Jun 15, 2017 11:32 pm
That sounds more like a compressor failure to be honest, it's classic symptoms of that failed.
K.
"Sometimes you get the best light from a burning bridge" Don Henley
Cheap appliance spare parts in our store Find an appliance repair company here
User avatar
kwatt
Appliance Forum Administrator
by Neil1987 » Fri Jun 16, 2017 2:58 pm
Ffs! Not what I needed to hear, but appreciated, thanks for your reply
User avatar
Neil1987
Whitegoods Newbie
Whitegoods Newbie
shop spare parts
Return to Fridge And Freezer Forum
