Washing Machine Help Forum
Bosch WFF2000GB/14 Starts spinning then stops, repeatedly
This forum is for support, help and questions you have about washing machines and washer dryers. For washing machine spares click here
Get spare parts for washing machines
Buy washing machine spare parts in our store for all major washing machine makes and models including many low cost compatible spares or contact us and we will find the parts you need for you
by tom_w » Fri Feb 17, 2017 4:54 pm
Hi
My Bosch is no longer spinning properly, it starts to spin for a second and then just spins down. It does this repeatedly throughout the spin part of the cycle. At the end of the cycle it's flashing four times on the pre-wash light.
I've changed the brushes which hasn't helped and as far as I can see they seem to be touching the armature correctly. Does anybody know what else might be causing this behaviour?
User avatar
tom_w
Whitegoods Newbie
Whitegoods Newbie
by Martin » Fri Feb 17, 2017 7:22 pm
Were the old brushes worn out and blackened?
User avatar
Martin
Appliance Master
Appliance Master
by tom_w » Fri Feb 17, 2017 10:56 pm
They don't look that bad to me, but I have nothing to judge them against:
User avatar
tom_w
Whitegoods Newbie
Whitegoods Newbie
by Martin » Sat Feb 18, 2017 8:59 am
They look OK. So, next question, if you were to put it now on a wash cycle, would would it fill and tumble OK?
User avatar
Martin
Appliance Master
Appliance Master
by tom_w » Tue Feb 21, 2017 9:14 pm
Thanks Martin. I started it off on a normal wash and it did the same thing through the initial tumbling bit, spinning up briefly then stopping again, albeit more quickly (maybe due to the water resistance?). The water level was about an inch deep in the drum. It then did the same thing when it hits the first rinse spin.
I'm running it empty at the moment, I'm assuming it's not realising that and stopping.
User avatar
tom_w
Whitegoods Newbie
Whitegoods Newbie
by Martin » Wed Feb 22, 2017 8:07 am
The good news:
The motor connecting plug wires may have been damaged? Carefully check the wires into that connecting block.
The real bad news:
The 'tachometer generator' magnet on the motor's armature shaft has likely cracked and is broken. You'll need to remove and dismantle the motor and inspect that magnet. If that is the case then it's the end of the road for your machine as a new motor is the only resolve.
User avatar
Martin
Appliance Master
Appliance Master
by tom_w » Thu Feb 23, 2017 8:14 pm
Real bad news it is:
Such a shame, it looks pretty much brand new other than that and it looks so well engineered, much better quality than the Hoover one I replaced a belt on a while ago.
Any recommendations for the replacement?
Many thanks for all the help, it's good to know I did what I could anyway!
User avatar
tom_w
Whitegoods Newbie
Whitegoods Newbie
 Washing machine door seal gaskets
If need a new door seal for your washing machine you can buy a replacement seal in our store here for all major washing machine brands with many low cost compatible seals available and many other washing machine spare parts. And for more detailed advice or support on how to replace a washing machine door gasket please see our fitting instructions here
A washing machine door seal or gasket, an important part in your washing machine
Return to Washing Machine Help Forum
