Washing Machine Help Forum
Hotpoint WD62P motor replacement
This forum is for support, help and questions you have about washing machines and washer dryers. For washing machine spares click here
Get spare parts for washing machines
Buy washing machine spare parts in our store for all major washing machine makes and models including many low cost compatible spares or contact us and we will find the parts you need for you
by GrahamManchester » Tue Mar 13, 2018 5:14 pm
Hello all,
I have swapped the motor in my mum's WD62P for a new "ACC" labelled one (previous was the original GDA? version). The new motor is a UOZ 112 G 55 084315; code: 16.40.2017 04 and I am confident that this is the correct one. I have read however, that a motor plug change (on the end of the wiring loom) is sometimes required. There exists a document describing the modification: leaflet No. 8200653 that comes with an FHP motor - does the same apply for this ACC one? I have not been able to find this leaflet on the web.
Thanks Graham :?:
User avatar
GrahamManchester
Whitegoods Newbie
Whitegoods Newbie
 Washing machine drain pumps & parts
If your washing machine will not drain the cause will normally be that either your drain pump is blocked or faulty resulting in the machine failing to empty. You can buy replacement drain pump including many low cost compatible washing machine pumps in our store to fit all major washing machine makes including AEG, Beko, Hotpoint, Bosch and many more
Drain pumps for most washing machines including popular makes like AEG, Hotpoint, Beko, Baumatic, Bosch and many more
by electrofix » Tue Mar 13, 2018 6:38 pm
originally they used to supply a new motor with the correct plug but you also needed the correct tool to fit it
when a plug change was needed I think it was a longer plug ( more terminals) also the wiring order of the plug was different
post a few pictures
Dave
User avatar
electrofix
Appliance Forum Moderator
by GrahamManchester » Tue Mar 13, 2018 7:08 pm
Thanks Dave,
The motor and plug both have 7 pins and they do mate with a bit of a push (it's the same size of plug but 2 of the 3 ident. notches don't match up . I heard that the 2 tacho. wires were in a different position between the different motors, but they actually match up, so I'm not sure if there is an issue with this ACC motor.
Graham
User avatar
GrahamManchester
Whitegoods Newbie
Whitegoods Newbie
by electrofix » Tue Mar 13, 2018 8:16 pm
have you tried it to see if it runs ?
also some of the later programme boards have a 7A fuse on the board for the motor so if your old motor went pop the fuse may have gone
Dave
User avatar
electrofix
by iadom » Tue Mar 13, 2018 11:28 pm
As long as you match up the wires to the tacho on the old motor to the connections to the tacho on the new motor it will work fine without any other changes. Assuming as Dave said that no other damage has been done.
Nothing really matters much, and hardly anything really matters at all.
User avatar
iadom
by GrahamManchester » Wed Mar 14, 2018 12:14 am
Thanks both,
I'll find out tomorrow when I power it up, I'll let you know what happens ..!
User avatar
GrahamManchester
Whitegoods Newbie
Whitegoods Newbie
by GrahamManchester » Thu Mar 15, 2018 1:47 am
Hello again,
I switched the machine on yesterday, and it worked fine!
The W/M is 20 years old and I've just replaced the door switch too. The drum bearings are quiet and there's just a leak to sort out where the dryer blower attaches to the drum - an o-ring maybe? Anyway that's a job for another weekend...
Thanks for all your advice.
Graham.
User avatar
GrahamManchester
Whitegoods Newbie
Whitegoods Newbie
Does your washing machine stink?
If your washing machine stinks, smells bad or emits strange odours it is most likely to be caused by bacteria build up in the washer. To clean this we recommend using Affresh that you can buy here to clean out the bacteria. And for more detailed advice on washing machine odour you can read our article all about smelly washing machines here
Buy Affresh washing machine cleaner here to stop bad smells from your washing machine
Return to Washing Machine Help Forum
