Washing Machine Help Forum
ISE W1706W - won't turn on
This forum is for support, help and questions you have about washing machines and washer dryers. For washing machine spares click here
Get spare parts for washing machines
Buy washing machine spare parts in our store for all major washing machine makes and models including many low cost compatible spares or contact us and we will find the parts you need for you
by martin-h » Wed Jun 13, 2018 6:38 pm
I have an ISE W1706W which has worked faultlessly for several years. Last week it wouldn't turn on - there was no sign of life at all.
I could see that there was a blown resistor on the board - replaced it and it blew again. Following the advice on this thread: http://www.ukwhitegoods.co.uk/forumsphpbb3/post458721.html#p458721 I checked the voltage control chip - it had also blown (but harder to see the damage).
I have now replaced both components, but there is still no sign of life at all. I have confirmed that there is mains power going to the board. There's no other damage that I can see.
Is a replacement control module the next step, or can anyone suggest something else first?
User avatar
martin-h
Appliance Forum User
 Before you post it… search it!
Please, before you post and ask something that has been asked before (often many times) please use the search facilities available.
Here you can search the forums only, including trade forums with permissions
Here you can search the entire site including all articles, public forums and online store
Use the search function before you post!
by electrofix » Wed Jun 13, 2018 7:18 pm
sometimes when the power chip fails the electrical surge damages the logic chips.
the only other chip you could look at is the other regulator chip which I labelled with a yellow arrow
After that you have to be able to measure voltages on the board safely to continue other than that is a new board
Dave
User avatar
electrofix
Appliance Forum Moderator
by martin-h » Wed Jun 13, 2018 7:28 pm
Hi Dave,
Many thanks for the speedy response.
There's no sign of damage on that other chip. Presumably I should look for 5v or so across 2 of the pins on that chip?
Martin
User avatar
martin-h
by electrofix » Wed Jun 13, 2018 8:02 pm
the other chip looks like a standard reg chip
so the 3 pins are
voltage in
voltage out
and the heatsink should be chassis
you measure between chassis and each of the pins in turn. A lot of these chips have numbers on the like 7812 or 7805. last 2 digits are voltage output
input voltage should be the same as the output voltage of the main 7 leg chip
one word of warning!! The 7 leg chip you changed has a voltage input of over 300 volts DC so playing with a live circuit can be dangerous and as a site we cant condone it
Dave
User avatar
electrofix
by martin-h » Wed Jun 13, 2018 8:25 pm
Thanks again. Point taken re the high voltage!
The thing that I'd thought was a voltage regulator turns out to be a Triac - I've only just been able to identify the part number on it. I can't see anything else that looks like a 3-pin regulator - images attached in case I've missed something blindingly obvious.
I'm thinking now that it's got to be a new control module (£190) or a replacement machine. Do you think there's much of a risk that the new module will not fix the problem?
Cheers,
Martin
User avatar
martin-h
by electrofix » Wed Jun 13, 2018 8:45 pm
ah was assuming you were talking about the same boards as pictured and you fooled me. So yours may not have a reg chip
right brown cap at top of picture 1 should be high voltage. mains is rectified and you end up with over 300 volts DC
the 7 leg chip takes this voltage and lowers it to about 12 for the board. I would expect the 2 black caps to be 16v working or so. If you can safely measure the voltage on these to see what you get
one thing to mention is the 7 leg chip has a system known as fold back. this system lowers the out put if the current exceeds set limits. So if you measure the voltage and you find it going up and down then there is probably a short on one of the other main chips
Dave
User avatar
electrofix
by martin-h » Wed Jun 13, 2018 8:57 pm
Apologies for the confusion.
I'm getting about 1.1v across one of the black capacitors (fluctuates slightly but only about 0.03v or so)
User avatar
martin-h
by electrofix » Wed Jun 13, 2018 9:10 pm
well that's fat too low. would expect min 5v up to poss 12 but never 1.1 v
if you can find a power supply reason then ok. if its a short causing fold back then you need a new board.
it looks like this machine has 2 boards linked by ribbon cables. try unplugging them and test again. If voltage comes up other board has fault
dave
User avatar
electrofix
by martin-h » Wed Jun 13, 2018 9:16 pm
drops to zero with the cables unplugged
User avatar
martin-h
by electrofix » Wed Jun 13, 2018 9:58 pm
it does sort of sound like your power supply is not functioning. Don't know why as you can imagine but something does not ring true. since the 7 leg chip provides the power I would not expect the voltage to go down once the ribbons are removed
take it there are no components to speak of on the underside of that board
Dave
Dave
User avatar
electrofix
by martin-h » Thu Jun 14, 2018 7:16 am
Hi Dave,
The second board has a STM8S207 microcontroller chip plus a couple of other chips.
User avatar
martin-h
shop spare parts
Return to Washing Machine Help Forum
