Cooker And Oven Forum
Oven igniter won’t stop clicking - cannon 10750G
This forum is for any cooking appliances that you need help with like cookers, ovens, hobs, hoods & microwaves. For cooker and oven spares click here
Get oven and cooker spare parts
Buy spare parts in our store for built in ones and cookers including range cookers with many low cost compatible spares available or contact us and we will find the parts you need for you
shop spare parts
by Yog » Thu Jul 12, 2018 6:57 am
The RH oven on our Cannon 10750G works ok but the igniter won’t shut off. It lights the burner but then just carries on sparking. It’s been working fine til now. Oven temp seems ok but the clicking is driving us nuts!
Update: I disconnected the spade from the electrode and when I turned the gas on it still carried on clicking even though there was no sparking off the detached end. Does that mean it’s sparking somewhere else on the circuit?
User avatar
Yog
Appliance Forum User
 Oven & cooker door hinges
If the door on your built in oven or cooker isn’t closing properly it’s almost certain that the door hinges will need to be replaced. Find replacement door hinges in our store for all major brands including Hotpoint, Britannia, Beko, Rosieres, Stoves, Smeg and many more
Buy oven door hinges for built in ovens and cookers online
by electrofix » Thu Jul 12, 2018 7:45 am
the igniter should detect the flame and shut off which means its faulty
Dave
User avatar
electrofix
Appliance Forum Moderator
by Yog » Thu Jul 12, 2018 8:27 am
Where’s the fault though? In the electrode? The igniter lead or the actual spark generator which supplies all the igniters and sits under the hob?
User avatar
Yog
by electrofix » Thu Jul 12, 2018 8:31 am
very likely the spark generator
if it was the electrode it would not ignite nor would it if the lead was faulty
Dave
User avatar
electrofix
by Yog » Thu Jul 12, 2018 9:36 am
I’ve seen the spark generator. Plastic box with a bunch of spade connectors, under the hob? Anyone know where’s a good place to get a replacement and are they model-specific?
User avatar
Yog
by kaibart » Thu Jul 12, 2018 9:58 am
This is something that needs to be done by a gas safe engineer
User avatar
kaibart
Valued Contributor
Valued Contributor
by electrofix » Thu Jul 12, 2018 11:33 am
you have to get the correct part for your appliance otherwise it may not function properly
looks like this one
https://www.cannon-spares.com/extended_ ... 0c8S7jTXcs
Dave
User avatar
electrofix
by Yog » Thu Jul 12, 2018 8:15 pm
kaibart wrote:This is something that needs to be done by a gas safe engineer
Really? I’ve had the hob top off before. No need to touch the gas, not on this cooker anyway. Just a few screws and it lifts off. And there is the spark generator, which is only spade connectors. The gas supply isn’t involved.
User avatar
Yog
by don » Fri Jul 13, 2018 7:33 am
Hi
Kaibart is quite correct in his recommendation of a Gas Safe engineer to carry out this repair on a gas or dual fuel appliance.
There is a link at the top of this forum which explains the reasons why. Click this link for the page.
Don
Please keep your questions to the forums, emails and private messages will not be answered.
User avatar
don
 Is your oven not heating up?
Should your oven not heat up then there is a good chance that the fan heating element has failed. Find a new one in our store including many low cost compatible heating elements for all major brands and we will support you in finding the element you need but also check thermostats including any safety thermostats that many modern ovens and cookers have fitted
Buy Fan oven elements and other heating elements for built in ovens and cookers online
Return to Cooker And Oven Forum
